Re: Lowering blocks advice
From Melbourne, Australia
hmm, i quickly read that and didnt see a mention of the locator pin, the block should have a bolt through the center holding it to the leafs (otherwise they are not legal), the bolt head also locates the diff
make sure you tighten this bolt a second time after you tighten the u-bolts aswell
also you can get longer u-bolts off vanettes and stuff if your a tight arse like me
Posted on: 2003/12/18 2:37
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Subject Poster Date
     Lowering blocks advice B120dat 2003/12/17 23:54
       Re: Lowering blocks advice B110SSS 2003/12/18 0:36
       Re: Lowering blocks advice B120dat 2003/12/18 0:36
         Re: Lowering blocks advice B120dat 2003/12/18 0:42
         Re: Lowering blocks advice Buff 2003/12/18 0:46
           Re: Lowering blocks advice B110SSS 2003/12/18 1:50
             Re: Lowering blocks advice Demojob 2003/12/18 2:04
               Re: Lowering blocks advice 1200rallycar 2003/12/18 2:37
