« 1 (2)
Re: It's alive!
From Okinawa, Japan
So hooking it up to a ported vacuum fitting ONE of the carbs would be okay then? (there's 4)
Posted on: 2003/12/18 15:14
Re: It's alive!
It would work if all four carbs can see the same vacuum signal. By that i mean that an isolated runner manifold design would be a problem, & linking to all four carbs wiuld be best, but if all the runners are kinked with a balance pipe, you should be able to get away with one.
Anyone else care to contribute?
Posted on: 2003/12/19 11:40
Love your Datsun.
Treat it well.
Re: It's alive!
From Oregon, USA
If he has 4 throttle plates with individual runners, and vacuum coincides with the opening of the intake valve, I'm quite sure he'll need to take vacuum from all 4 carbs/throttles. Otherwise won't the dizzy see "pulses" of vacuum?
Posted on: 2003/12/19 15:48
« 1 (2)
