Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
A12 ARP bolt kit vs A14 ARP kit
1200GXman
Posted on: 2010/6/4 6:22
Hi
I am posting on behalf of Clive. He bought a ARP stud (for the cylinder head bolt down) and ARP conrod kit and they were listed for A12 engine. He is going to use it on a A14/A15 engine. Will it work?
#2
Re: A12 ARP bolt kit vs A14 ARP kit
Posted on: 2010/6/4 8:06
Already discussed several times this year
ARP Brand connecting rod stud set * 102-6002 The same rod studs are used by all A-series engines, from A12 to A15. http://datsun1200.com/modules/mediawi ... le=Engine_block#Rod_Studs
#3
Dundee1000
Posted on: 2010/9/2 11:18
old post drag up.. he's asking about Head studs.. not rod bolts DD..
#4
Dodgeman
Posted on: 2010/9/3 16:46
He needs to be carefull about which A12 is being refered to.
Since the cylinder head stud kit that he bought seems to be listed for the A12 & not "All A series except 1966-'73 A10 & A12" I would assume that it is for the earlier engine. The later engines [mid mounted distributor] [1974 --> A12, A12A, A13, A14, A15] have one bolt that is longer than the others, so I would expect the ARP stud kit for these engines to also have one stud that is longer. The earlier engines [forward mounted distributor types] have ten head bolts that are the same length as each other so I would expect that the stud kit would also follow this pattern. You can view topic.
