« 1 (2) 3 4 5 ... 8 »
Re: 1200 UTE CA18DET - PERTH
From Mandurah, Western Australia
Good luck with the conversion
Jack Agpar is good, he gave me a bit of advice when I first started my conversion, but in the end dianella is a fair drive from my place.
Mine is full engineered at the moment if you got any questions.
Posted on: 2010/9/8 14:33
old_school's 1200 coupe
cheers, old_school, i think i will be needing that luck. im sure i'll have some questions throughout the build. i think it will be worth ringin jack and having a chat about the engineering.
Posted on: 2010/9/8 14:45
From mandurah
Posted on: 2010/9/8 15:06
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From mandurah
Posted on: 2010/9/8 15:09
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
worked a treat, cheers.
Posted on: 2010/9/8 15:14
From mandurah
have you thought about your brakes yet ?? i dont think the silvia brakes would be good for rego cos you then have to get the adaptor brackets signed off ,but you could go for land cruiser like old_school is or commo like i am
for rego i would change as little as possible ,the more you change the more that needs signing of ,jarrad is full book on this stuff ,cos he has been through it and survived
Posted on: 2010/9/8 15:19
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
im hoping to use the whole s13 strut. use s13 lower control arm, s13 outer tie rods, r31 radius rods. im just hoping the track width doesnt increase beyond engineering. will try fit and see what happens i spose.
Posted on: 2010/9/8 15:24
u picked up the white one for sale a few weeks back? was advertised for 3800?
Posted on: 2010/9/9 3:26
nah, was on gumtree in wanneroo got it for 4k. its in awesome condition. small spot of rust in tray, a tiny spec on the roof and thats it. went over it with a magnet and no big patches of bog. once the engine and driveline is fitted up, it will get sodablasted so we'll see what its really like.
Posted on: 2010/9/9 4:25
From mandurah
dont soda blast it if you want a ute when it comes back
most utes are fuked ,including mine haha
Posted on: 2010/9/9 10:01
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
