Browsing this Thread:
1 Anonymous Users
Re: A14/15 turbo~280hp, bore question |
From Forsby Finland
This is so much help, thank you guys! Seems like I have to use sleeves in my engine setup to get the reability that I am aming for. I am not aiming for a high boost engine, rather a high comp engine that produces much power at relatively low boost. I am planning to use a Garret GT25R turbo. One of my mates who has a SR20 in his Cherry/Pulsar producing massive 915hp at 42psi boost hasnīt had any problems with the bottomend since he mounted Darton sleeves in the block, and itīs not o-ringed! www.woken.se/wok/2007/dyno_feb07/bromspapper_ras.jpg He has driven 9,54 on the quartermile...... A 2 litre A14 would be really crazy, in my setup I would get problems with the bottom end and the oil-pan... the 82mm crank fits without problem but there are no space left... I canīt use a deeper oil-pan because of the gearbox sitting underneath the engine! Please keep me uptodate, I will send post and pictures during my project! M Quote: Lemonhead wrote: The block that I have had bored to suit 82mm pistons has had a sleeve put in numbers 1 and 4 cylinders and 2 and 3 bored in original material.
This would work, but I am not happy with the arrangement of the bores, no.'s 1 and 4 have been moved to the front and rear of the block and 2 and 3 closer to the centre a bit. This has not given me the bore spacing/combustion chamber alignment that I wanted for the twin cam head nor a A-series head.
So, what I am doing now hopefully is what I originally wanted and that was a full wet sleeve block, I say hopefully because I have a dummy block at my machinist shop to see if we can do it, he's a 'can do' type of bloke and he can't see why we couldn't do it.
With the type of sleeves we are planning on using we can incorporate a raised ring around the bore (about 1mm high) to act as an O ring type of arrangement, with the sleeve thickness, 82mm is just the beginning of bore sizes, it will be interesting to see what size I can go to, coupled with the 88mm stroke crank I should be able to get some good capacity out of a little ol' 1400 block, 88mm x 85mm is 1997cc
I have recently acquired Feral's A13 raised port race head to intially put on the motor while I keep working on the twin cam, I have literally worn out my huge race head which is currently on rally car.
So if the wet sleeving does work, even with a 82mm stroke crank some good capacity can be achieved and to answer the theme of the thread - yes be perfect for high boost applications.
I will keep you posted.
D - From the other thread, I can build you whatever combination you desire
Marcus - I ran a 79mm n/a motor for a long time with no problems, had the block sonic tested and bored to suit, I like your signature, I guess I'm building honest 200hp n/a A-series motor.
Posted on: 2010/9/11 7:53
I am building a mean Datsun E10 racer  , a15 turbocharged engine, aiming for 280hp....
| Subject |
Poster |
Date |
Datsun100ATurbo |
2010/9/9 8:30 |
ddgonzal |
2010/9/9 8:40 |
Datsun100ATurbo |
2010/9/9 8:58 |
ddgonzal |
2010/9/9 9:06 |
clyons8 |
2010/9/9 14:57 |
Datsun100ATurbo |
2010/9/9 18:31 |
reuby_tuesday |
2010/9/10 0:11 |
PIGDOG |
2010/9/10 1:17 |
D |
2010/9/10 6:59 |
Datsun100ATurbo |
2010/9/10 9:46 |
Datsun100ATurbo |
2010/9/9 18:16 |
Dodgeman |
2010/9/15 15:06 |
A14force |
2010/9/11 0:03 |
Lemonhead |
2010/9/11 0:45 |
D |
2010/9/11 2:58 |
ddgonzal |
2010/9/11 6:16 |
Datsun100ATurbo |
2010/9/14 18:46 |
Datsun100ATurbo |
2010/9/11 7:53 |
Datsun100ATurbo |
2010/9/11 7:27 |
A14force |
2010/9/17 7:36 |
Datsun100ATurbo |
2010/9/17 18:20 |
A14force |
2010/9/15 6:39 |
Datsun100ATurbo |
2010/9/15 18:30 |
jmac |
2010/9/16 8:18 |
reuby_tuesday |
2010/9/16 8:40 |
jmac |
2010/9/17 7:30 |
D |
2010/9/18 3:43 |
Datsun100ATurbo |
2010/9/18 18:22 |
D |
2010/9/19 10:55 |
jmac |
2010/9/19 11:19 |
Datsun100ATurbo |
2010/9/19 19:47 |
D |
2010/9/20 2:12 |
Datsun100ATurbo |
2010/9/23 20:38 |
A14force |
2010/9/24 21:51 |
nick_m |
2010/9/24 22:12 |
ddgonzal |
2010/9/25 2:42 |
Datsun100ATurbo |
2010/9/25 13:23 |
Datsun100ATurbo |
2010/9/25 7:39 |
clyons8 |
2010/9/25 7:46 |
Datsun100ATurbo |
2010/9/25 7:37 |
rockstardan |
2010/9/25 8:37 |
D |
2010/9/25 12:13 |
Datsun100ATurbo |
2010/9/25 13:33 |
clyons8 |
2010/9/25 23:52 |
nick_m |
2010/9/26 0:01 |
Datsun100ATurbo |
2010/9/25 13:27 |
clyons8 |
2010/9/26 0:26 |
jmac |
2010/9/27 10:05 |
Datsun100ATurbo |
2010/9/27 19:52 |
jmac |
2010/9/28 12:28 |
reuby_tuesday |
2010/9/29 0:10 |
D |
2010/9/29 1:41 |
ssskiwi |
2010/9/29 1:53 |
reuby_tuesday |
2010/9/29 2:39 |
reuby_tuesday |
2010/9/29 2:47 |
jmac |
2010/9/29 8:05 |
reuby_tuesday |
2010/9/29 8:31 |
Datsun100ATurbo |
2010/9/29 11:01 |
Datsun100ATurbo |
2010/9/29 20:38 |
reuby_tuesday |
2010/9/29 23:23 |
Datsun100ATurbo |
2010/9/30 20:17 |
D |
2010/9/30 3:26 |
Datsun100ATurbo |
2010/9/30 20:30 |
Datsun100ATurbo |
2010/9/30 20:32 |
picko |
2010/9/30 9:34 |
reuby_tuesday |
2010/9/30 10:11 |
PIGDOG |
2010/9/30 11:50 |
reuby_tuesday |
2010/9/30 12:50 |
estyre |
2010/9/30 13:00 |
nick_m |
2010/9/30 12:58 |
picko |
2010/9/30 15:13 |
reuby_tuesday |
2010/10/1 0:55 |
PIGDOG |
2010/10/1 4:25 |
reuby_tuesday |
2010/10/1 5:39 |
PIGDOG |
2010/10/1 5:54 |
D |
2010/10/1 7:05 |
reuby_tuesday |
2010/10/1 7:13 |
Datsun100ATurbo |
2010/10/1 20:40 |
Datsun100ATurbo |
2010/10/1 20:44 |
reuby_tuesday |
2010/10/1 23:22 |
Fandatstick |
2010/10/2 0:42 |
D |
2010/10/2 4:14 |
Datsun100ATurbo |
2010/10/2 8:44 |
Datsun100ATurbo |
2010/10/2 8:33 |
A14force |
2010/10/3 6:20 |
Datsun100ATurbo |
2010/10/3 8:11 |
Datsun100ATurbo |
2010/10/3 8:35 |
D |
2010/10/3 11:13 |
Datsun100ATurbo |
2010/10/4 18:25 |
Lemonhead |
2010/10/3 13:03 |
Datsun100ATurbo |
2010/10/4 18:34 |
reuby_tuesday |
2010/10/5 0:22 |
D |
2010/10/7 1:52 |
D |
2010/10/11 0:03 |
Datsun100ATurbo |
2010/10/12 18:13 |
Datsun100ATurbo |
2010/10/26 19:19 |
D |
2010/10/27 0:07 |
Datsun100ATurbo |
2010/10/27 19:31 |
D |
2010/10/28 5:40 |
Datsun100ATurbo |
2010/10/30 8:31 |
D |
2010/10/15 5:01 |
D |
2010/10/30 0:53 |
Datsun100ATurbo |
2010/10/30 8:40 |
D |
2010/10/30 12:30 |
Datsun100ATurbo |
2010/11/6 13:46 |
jmac |
2010/11/8 8:24 |
clyons8 |
2010/11/8 9:00 |
Lemonhead |
2010/11/8 10:04 |
D |
2010/11/8 10:47 |
Lemonhead |
2010/11/8 12:21 |
jmac |
2010/11/8 12:00 |
clyons8 |
2010/11/8 12:12 |
D |
2010/11/9 5:47 |
jmac |
2010/11/15 10:27 |
Datsun100ATurbo |
2011/4/5 19:43 |
D |
2011/4/6 0:31 |
Datsun100ATurbo |
2011/4/6 18:46 |
D |
2011/4/7 0:55 |
Datsun100ATurbo |
2011/4/7 5:54 |
dattoman_1000 |
2011/4/7 1:14 |
Datsun100ATurbo |
2011/4/7 5:55 |
dattoman_1000 |
2011/4/7 13:52 |
D |
2011/4/7 14:26 |
clyons8 |
2011/4/7 16:49 |
Datsun100ATurbo |
2011/4/7 19:53 |
D |
2011/4/8 1:12 |
Datsun100ATurbo |
2011/4/8 19:07 |
Datsun100ATurbo |
2011/4/17 16:40 |
roadstar79 |
2013/7/2 13:00 |
