Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Forum project - Distributor maps
spraycanmansam
Posted on: 2010/9/15 10:18
Hi guys,
I'm switching over to programmable ignition in the next week or so (Megajolt) I've been hunting for any references to the stock datsun dizzys curves, found one so far: ![]() If anyone knows of or has any more maps for datsun distributors feel free to add them. What I would like to do is adapt one of these curves to the programmable ignition map like this: ![]() All the load and rpm scales can be adjusted if needed. I need a little help adapting this to the Megajolt map. I thought it would be good if you could have a stock datsun dizzy curve to start as a base-line for further tuning.. Others could even upload links to their custom maps in an excel sheet etc into this thread to keep a repository for any fellow datsun owner changing to programable ignition... Cheers, Sam
#2
Re: Forum project - Distributor maps :)
Posted on: 2010/9/16 2:38
Here is the factory A12 map:
cylinders=4 mapBins=80,73,66,60,53,46,39,33,26,19 rpmBins=6,10,14,18,22,27,31,35,39,43 advance0=18,21,24,27,30,33,36,39,42,45 advance1=17,20,23,26,29,32,35,38,41,44 advance2=15,18,21,24,27,30,33,36,39,42 advance3=14,17,20,23,26,29,32,35,38,41 advance4=12,15,18,21,24,27,30,33,36,39 advance5=11,14,17,20,23,26,29,32,35,38 advance6=9,12,15,18,21,24,27,30,33,36 advance7=8,11,14,17,20,23,26,29,32,35 advance8=6,9,12,15,18,21,24,27,30,33 advance9=5,8,11,14,17,20,23,26,29,32 I will send you the Excel spreadsheet. You can put new numbers in it and it will generate numbers like the above.
#3
spraycanmansam
Posted on: 2010/9/16 3:10
Mate your a bloody champion :)
#4
Posted on: 2010/9/16 3:59
You can also open the Megajolt file in notepad and just paste that in. It is the .mjlj file.
