Forum project - Distributor maps
Hi guys,
I'm switching over to programmable ignition in the next week or so (Megajolt)
I've been hunting for any references to the stock datsun dizzys curves, found one so far:
If anyone knows of or has any more maps for datsun distributors feel free to add them.
What I would like to do is adapt one of these curves to the programmable ignition map like this:
All the load and rpm scales can be adjusted if needed.
I need a little help adapting this to the Megajolt map.
I thought it would be good if you could have a stock datsun dizzy curve to start as a base-line for further tuning..
Others could even upload links to their custom maps in an excel sheet etc into this thread to keep a repository for any fellow datsun owner changing to programable ignition...
Cheers,
Sam
Posted on: 2010/9/15 10:18
Edited by spraycanmansam on 2021/1/27 6:18:47
Re: Forum project - Distributor maps :)
Here is the factory A12 map:
cylinders=4
mapBins=80,73,66,60,53,46,39,33,26,19
rpmBins=6,10,14,18,22,27,31,35,39,43
advance0=18,21,24,27,30,33,36,39,42,45
advance1=17,20,23,26,29,32,35,38,41,44
advance2=15,18,21,24,27,30,33,36,39,42
advance3=14,17,20,23,26,29,32,35,38,41
advance4=12,15,18,21,24,27,30,33,36,39
advance5=11,14,17,20,23,26,29,32,35,38
advance6=9,12,15,18,21,24,27,30,33,36
advance7=8,11,14,17,20,23,26,29,32,35
advance8=6,9,12,15,18,21,24,27,30,33
advance9=5,8,11,14,17,20,23,26,29,32
I will send you the Excel spreadsheet. You can put new numbers in it and it will generate numbers like the above.
Posted on: 2010/9/16 2:38
Mate your a bloody champion :)
Posted on: 2010/9/16 3:10
Edited by spraycanmansam on 2021/1/27 6:19:18
You can also open the Megajolt file in notepad and just paste that in. It is the .mjlj file.
Posted on: 2010/9/16 3:59
