Re: wrx engine in dato 1200 ute
Also
Charlies advice was good, but taking a tape measure to the subject components in any proposed conversion will provide much needed info very quickly, as i'm sure you know, & i'm sure that you have done many times.
This is exactly why Charlie said find out as much as possible now.
But did you bother giving Mattymac this helpful advice? No
Posted on: 2003/12/26 1:37
From Arlington, TX, USA
As a matter of redirect, it's a neat idea and would be pretty cool once finished, but the effort involved is likely way more than the result gained. If you're okay with that, then forge ahead. If not, then don't.
I don't think you could legitimately convince yourself or anyone else that this would be anything less than a monumental effort. But as stated, I'd wager there was a time when someone said it was crazy to stick an A14 into a 1200.
Posted on: 2003/12/27 3:05
1973 Datsun B110 Coupe (A15/5spd)
1977 Datsun 280Zed (5.0L/5spd)
From Canberra
Definately a different idea but as said before the effort involved may not be worth the results. Another option if you want 4WD(again probably nearly as difficult) would be the GTiR running gear. SR20DET, quad throttle and AWD. That keeps it in the Datto/Nissan family but again would probably be a very complex conversion.
I have seen the WRX engine conversion in a fair few brumbies (with excellent results).
Posted on: 2003/12/27 23:24
www.valvebounce.com
motorsport and performance forum
The Subaru Brumby -- since it already has a Subaru flat-four -- should be a relatively straightforward swap. The Brumby was called the Subaru "Brat" in the US.
Fitting a Subaru powertrain in the back of a 1200 ute is certainly not a "bolt in" project, but if you are good at welding roll cages and such it wouldn't seem to be much different from other tube-frame based race car projects ... seems certainly do-able.
Anyone remember the "Hurst Hairy Oldsmobile"? When the new 1966 fwd Olds Toronado debuted, Hurst had one built with a duplicate fwd unit fitted in the back seat area, in other words dual-engined. It would smoke all four tires down the quarter mile.
Posted on: 2003/12/28 2:23
Bump!
Just so its easy for you to find storyteller.
Posted on: 2004/1/3 11:53
Buy the way storyteller, how many times do you go back through and re-edit your posts?
I do notice you have reworded many of your posts..
Posted on: 2004/1/3 14:08
Hysterics does not become you & your accusations are the act of a man clutching at straws.
Your personal vendetta has become wearysome & your language objectionable. I decline to enter into further correspondence. Babble on & fabricate all you want.
Posted on: 2004/1/3 14:20
Love your Datsun.
Treat it well.
What no more stories?
How are the kids gonna fall asleep at night?
Posted on: 2004/1/3 14:28
Due to the substantial difference in width between the older and newer engines, it should not be considered a "given" that it will fit.
However, it would be AWESOME
And alot easier than putting it in a Datto.
Personally, I like the Sunny SR20 idea. It forces you to convert it to a longitudinal mounting, but it is a bit more do-able. And it keeps it all-Nissan.
Posted on: 2004/1/3 15:46
Dodgeman wrote:
My interpretation of the original post was a desire to install this as a two wheel, conventional drive swap, & not an AWD conversion.
One thing to remember with this style set-up is that the factory never intended it to be RWD only. You would have to disassemble the trans and either find a way to remove the center diff, or weld it solid and hope it doesn't break.
Posted on: 2004/1/3 15:51
« 1 (2) 3 »
