Re: what Causes this ?
That rotor looks perfectly normal.
To keep it going good, once a year scrape the black carbon off the edge.
most of the time i see cold start drops water from exhaust too
It is normal.
and yesterday i got a problem the car doesn't idle it suddenly dies in law rpm, but you can rev it as usually but doesn't sit idle , it is blocked idle jet(slow jet) right ?
The most common cause is partially blocked main jet, which is at the bottom of the fuel bowl, and from which the idle circuit draws fuel.
Posted on: 2010/9/28 2:49
Subject Poster Date
     what Causes this ? Sumith 2010/9/27 12:43
       Re: what Causes this ? ddgonzal 2010/9/28 2:49
         Re: what Causes this ? greendog 2010/9/28 6:00
         Re: what Causes this ? Sumith 2010/10/1 4:19
