points
From Brassall
hi! anyone know what the points gapping should be set at on a a12 motor? for some reason i think im getting some slight missfire seems to be when the engine is a little cold but its only on acceleration any suggestions pls? did notice the coil to be bloody hot and some slight click noise intermitantly (dodgey coil)?
Posted on: 2010/10/3 8:06
Re: points
From Brassall
ok, set points to about .50 seems to run smoother on idle, (i must have had it a bit too close). havent taken it for a drive yet to see if it still missfires...
Posted on: 2010/10/3 8:50
Re: points
From Melbourne, Australia
yeah book says .45-.55mm so .50 is perfect...
just did Datogals 1200 and that fixed a lot of problems, there was also a frayed wire inside the dizzy which i replaced
noticed with brand new points i couldn't set the gap to .5mm only about .3mm, i cracked it and went and got some clean looking points out of an old dizzy and its been humming beautiful since
Posted on: 2010/10/3 10:53
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: points
My Dattos have always run so much better and much better power by replacing points with one of the hall effect electronic ignitions like a Pertronix. Also heaps simpler to tune. I'll never bother with points ever again. Best $100 you can spend on a Datsun.
Posted on: 2010/10/3 12:14
Re: points
Points should be set at 49 to 55 degrees of dwell but go for 49 degrees & as the rubbing block wears it will move towards 55 degrees & it will stay within spec for longer.
Better yet, take SunnyDaze advice & get a Pertronix [or other] electronic conversion.
I did, & I added a GT40 coil & a set of platinum plugs for good measure. Starts first time, every time, & runs as sweet as you could ever wish.
Posted on: 2010/10/3 13:20
Love your Datsun.
Treat it well.
Re: points
From Sydney
electronic ignition!!!
Posted on: 2010/10/3 15:53
Re: points
From Sydney
why are you wasting your time with points for? go electronic you will save your self probs down the track, plus you get a much better spark nearly twice the spark and as the engine revs more n more you get that constant spark as to points as they get weaker as it revs...
Posted on: 2010/10/3 22:28
Re: points
From Malaysia
yeah agreed mate, best money spent on a datsun, is electric dizzy, and electric fan :)
Posted on: 2010/10/4 0:44
Re: points
From Brassall
ok ok, anyone use the hot spark elec ign conv?
http://cgi.ebay.com/ebaymotors/Electr ... uckQ5fPartsQ5fAccessories
Posted on: 2010/10/4 1:36
Re: points
See our Datsun1200.com club wiki: Hot-Spark Ignition
Posted on: 2010/10/4 3:10
