Re: A14/15 turbo~280hp, bore question
From Forsby Finland
I will try to cut it like you wanted, I am also interested to see the rest of the inside of the block! Even if I bore the block straight there will be atleast 2,5mm left on each cylinderwall and that might be enough!? It´s also possible to bore cyl 1 and 4 offset.
Here are some pics with appr. measures!
5,5mm
7mm
4,5mm
4,5mm
6mm
D wrote:
If you look at the following pics you can see the light blue line
indicating the depth at where it would be good to get a cut.
That way it can be seen what the base would be like where the
cylinder wall meet the floor of the water containment area.
Also Im thinking Marcus you will have trouble with 79mm bores on
the middle 2-3 webbing where its thinner than 1-2 or 3-4 areas.
Posted on: 2010/10/4 18:25
I am building a mean Datsun E10 racer , a15 turbocharged engine, aiming for 280hp....
Subject Poster Date
     A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/9 8:30
       Re: A14/15 turbo~280hp, bore question ddgonzal 2010/9/9 8:40
         Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/9 8:58
           Re: A14/15 turbo~280hp, bore question ddgonzal 2010/9/9 9:06
             Re: A14/15 turbo~280hp, bore question clyons8 2010/9/9 14:57
               Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/9 18:31
                 Re: A14/15 turbo~280hp, bore question reuby_tuesday 2010/9/10 0:11
                   Re: A14/15 turbo~280hp, bore question PIGDOG 2010/9/10 1:17
                     Re: A14/15 turbo~280hp, bore question D 2010/9/10 6:59
                       Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/10 9:46
             Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/9 18:16
         Re: A14/15 turbo~280hp, bore question Dodgeman 2010/9/15 15:06
       Re: A14/15 turbo~280hp, bore question A14force 2010/9/11 0:03
         Re: A14/15 turbo~280hp, bore question Lemonhead 2010/9/11 0:45
           Re: A14/15 turbo~280hp, bore question D 2010/9/11 2:58
             Re: A14/15 turbo~280hp, bore question ddgonzal 2010/9/11 6:16
               Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/14 18:46
           Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/11 7:53
         Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/11 7:27
         Re: A14/15 turbo~280hp, bore question A14force 2010/9/17 7:36
           Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/17 18:20
       Re: A14/15 turbo~280hp, bore question A14force 2010/9/15 6:39
         Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/15 18:30
       Re: A14/15 turbo~280hp, bore question jmac 2010/9/16 8:18
         Re: A14/15 turbo~280hp, bore question reuby_tuesday 2010/9/16 8:40
       Re: A14/15 turbo~280hp, bore question jmac 2010/9/17 7:30
       Re: A14/15 turbo~280hp, bore question D 2010/9/18 3:43
         Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/18 18:22
         Re: A14/15 turbo~280hp, bore question D 2010/9/19 10:55
       Re: A14/15 turbo~280hp, bore question jmac 2010/9/19 11:19
         Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/19 19:47
           Re: A14/15 turbo~280hp, bore question D 2010/9/20 2:12
         Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/23 20:38
       Re: A14/15 turbo~280hp, bore question A14force 2010/9/24 21:51
         Re: A14/15 turbo~280hp, bore question nick_m 2010/9/24 22:12
           Re: A14/15 turbo~280hp, bore question ddgonzal 2010/9/25 2:42
             Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/25 13:23
           Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/25 7:39
             Re: A14/15 turbo~280hp, bore question clyons8 2010/9/25 7:46
         Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/25 7:37
       Re: A14/15 turbo~280hp, bore question rockstardan 2010/9/25 8:37
         Re: A14/15 turbo~280hp, bore question D 2010/9/25 12:13
           Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/25 13:33
             Re: A14/15 turbo~280hp, bore question clyons8 2010/9/25 23:52
               Re: A14/15 turbo~280hp, bore question nick_m 2010/9/26 0:01
         Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/25 13:27
       Re: A14/15 turbo~280hp, bore question clyons8 2010/9/26 0:26
       Re: A14/15 turbo~280hp, bore question jmac 2010/9/27 10:05
         Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/27 19:52
       Re: A14/15 turbo~280hp, bore question jmac 2010/9/28 12:28
         Re: A14/15 turbo~280hp, bore question reuby_tuesday 2010/9/29 0:10
           Re: A14/15 turbo~280hp, bore question D 2010/9/29 1:41
             Re: A14/15 turbo~280hp, bore question ssskiwi 2010/9/29 1:53
               Re: A14/15 turbo~280hp, bore question reuby_tuesday 2010/9/29 2:39
                 Re: A14/15 turbo~280hp, bore question reuby_tuesday 2010/9/29 2:47
       Re: A14/15 turbo~280hp, bore question jmac 2010/9/29 8:05
         Re: A14/15 turbo~280hp, bore question reuby_tuesday 2010/9/29 8:31
           Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/29 11:01
             Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/29 20:38
               Re: A14/15 turbo~280hp, bore question reuby_tuesday 2010/9/29 23:23
                 Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/30 20:17
       Re: A14/15 turbo~280hp, bore question D 2010/9/30 3:26
         Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/30 20:30
           Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/30 20:32
       Re: A14/15 turbo~280hp, bore question picko 2010/9/30 9:34
         Re: A14/15 turbo~280hp, bore question reuby_tuesday 2010/9/30 10:11
       Re: A14/15 turbo~280hp, bore question PIGDOG 2010/9/30 11:50
         Re: A14/15 turbo~280hp, bore question reuby_tuesday 2010/9/30 12:50
           Re: A14/15 turbo~280hp, bore question estyre 2010/9/30 13:00
       Re: A14/15 turbo~280hp, bore question nick_m 2010/9/30 12:58
       Re: A14/15 turbo~280hp, bore question picko 2010/9/30 15:13
         Re: A14/15 turbo~280hp, bore question reuby_tuesday 2010/10/1 0:55
       Re: A14/15 turbo~280hp, bore question PIGDOG 2010/10/1 4:25
         Re: A14/15 turbo~280hp, bore question reuby_tuesday 2010/10/1 5:39
           Re: A14/15 turbo~280hp, bore question PIGDOG 2010/10/1 5:54
             Re: A14/15 turbo~280hp, bore question D 2010/10/1 7:05
             Re: A14/15 turbo~280hp, bore question reuby_tuesday 2010/10/1 7:13
         Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/10/1 20:40
           Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/10/1 20:44
             Re: A14/15 turbo~280hp, bore question reuby_tuesday 2010/10/1 23:22
             Re: A14/15 turbo~280hp, bore question Fandatstick 2010/10/2 0:42
               Re: A14/15 turbo~280hp, bore question D 2010/10/2 4:14
                 Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/10/2 8:44
               Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/10/2 8:33
       Re: A14/15 turbo~280hp, bore question A14force 2010/10/3 6:20
         Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/10/3 8:11
           Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/10/3 8:35
       Re: A14/15 turbo~280hp, bore question D 2010/10/3 11:13
         Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/10/4 18:25
       Re: A14/15 turbo~280hp, bore question Lemonhead 2010/10/3 13:03
         Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/10/4 18:34
           Re: A14/15 turbo~280hp, bore question reuby_tuesday 2010/10/5 0:22
       Re: A14/15 turbo~280hp, bore question D 2010/10/7 1:52
         Re: A14/15 turbo~280hp, bore question D 2010/10/11 0:03
           Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/10/12 18:13
             Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/10/26 19:19
               Re: A14/15 turbo~280hp, bore question D 2010/10/27 0:07
                 Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/10/27 19:31
                 Re: A14/15 turbo~280hp, bore question D 2010/10/28 5:40
                   Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/10/30 8:31
           Re: A14/15 turbo~280hp, bore question D 2010/10/15 5:01
       Re: A14/15 turbo~280hp, bore question D 2010/10/30 0:53
         Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/10/30 8:40
           Re: A14/15 turbo~280hp, bore question D 2010/10/30 12:30
             Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/11/6 13:46
       Re: A14/15 turbo~280hp, bore question jmac 2010/11/8 8:24
         Re: A14/15 turbo~280hp, bore question clyons8 2010/11/8 9:00
       Re: A14/15 turbo~280hp, bore question Lemonhead 2010/11/8 10:04
         Re: A14/15 turbo~280hp, bore question D 2010/11/8 10:47
           Re: A14/15 turbo~280hp, bore question Lemonhead 2010/11/8 12:21
       Re: A14/15 turbo~280hp, bore question jmac 2010/11/8 12:00
         Re: A14/15 turbo~280hp, bore question clyons8 2010/11/8 12:12
       Re: A14/15 turbo~280hp, bore question D 2010/11/9 5:47
       Re: A14/15 turbo~280hp, bore question jmac 2010/11/15 10:27
         Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2011/4/5 19:43
           Re: A14/15 turbo~280hp, bore question D 2011/4/6 0:31
             Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2011/4/6 18:46
               Re: A14/15 turbo~280hp, bore question D 2011/4/7 0:55
                 Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2011/4/7 5:54
       Re: A14/15 turbo~280hp, bore question dattoman_1000 2011/4/7 1:14
         Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2011/4/7 5:55
       Re: A14/15 turbo~280hp, bore question dattoman_1000 2011/4/7 13:52
         Re: A14/15 turbo~280hp, bore question D 2011/4/7 14:26
           Re: A14/15 turbo~280hp, bore question clyons8 2011/4/7 16:49
         Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2011/4/7 19:53
           Re: A14/15 turbo~280hp, bore question D 2011/4/8 1:12
             Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2011/4/8 19:07
               Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2011/4/17 16:40
       Re: A14/15 turbo~280hp, bore question roadstar79 2013/7/2 13:00
