HOW CAN I GO ELECTRONIC DIZZY FOR MY A14?
From Christchurch NZ
CAN ANYONE TELL ME THE BEST WAY TO GO ELECTRONIC IGNITION FOR AN A ENGINE? IS THERE ONE THAT WILL BOLT STRAIGHT IN? IF SO WHAT MODEL/YEAR COULD I GET ONE FROM? I HAVE ACCESS TO A MACHINE SHOP SO IF YOU HAVE EVER MADE ONE UP OUT OF TWO DIZZYS PLEASE TELL WHAT YOU USED & HOW YOU GOT ON . ANY ADVISE GREATLY APREACIATED.
Posted on: 2004/1/5 8:40
Forced Induction!
Re: HOW CAN I GO ELECTRONIC DIZZY FOR MY A14?
if you use the search button you will find plenty of info
Posted on: 2004/1/5 10:59
From Canberra, Australia
And if you use the capslock button it will be easier to read.
Here is a link to get your started:
http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=9659&forum=1#31543
Posted on: 2004/1/5 11:28
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
Quite a regular
From Taradale; NZ
Yes that is quite possible, i'm looking at doing that quite soon. Can open up spark plug gap etc.
Apparently early 80's Honda Civic or Nissan Pulsar of similar vintage. Each require different mods. One of them just requires machining of the bottom of the shaft housing. I'll try and get back to you with the specifics.
Posted on: 2004/1/6 8:00
No problems, only opportunities
