« 1 (2) 3 »
Re: E15 is there a rwd g/box that fit them
From Adelaide, Australia
as far as i know my brothers exa did over 300,000k's and he used to travel 1500k's at a time, once he pulled a trailer bigger than the car full of crap and hauled it 500ks and the only thing that had to be replaced on his car was the turbo (cause it was old) and we had new valves put in the head (cause it broke a timing belt that was way old) so in my opinion they are great motors, besides me and my other brother cained the #### out of it.
Posted on: 2004/1/5 10:40
From Millgrove Vic OZ
The E15T engine is in my experience very reliable, reasonably light, strongly constructed and worth doing as a replacement engine. I have one I built up in my VB11 van. On gas it made 180 FWhp with a modified T25.
The head problems they have usually result from cooling system faults left unattended such as clogged radiators.
Distributor problems result from moisture in electrical connections and distributor bodies. The dissys use a photo optical sender unit nearly identical to FJ20T and CA18DET's and are very reliable with good connections.
MRD (Murphy Racing Developments) in Bayswater Victoria has just run a high 10 second pass in their ET and it is very reliable.
I am looking at fitting one up with an A series 63A box to fit into a 4 door 310. I reckon they are great little engines that are under utilised for swaps.
Posted on: 2004/1/6 23:01
Cheers Feral
From Pakistan
feral wrote:I am looking at fitting one up with an A series 63A box to fit into a 4 door 310. I reckon they are great little engines that are under utilised for swaps.
hey Feral
i am also thinking this swap for my 4 dr B-310 but i dont want to cut my firewall, do u think a carby E15 will fit in b-310's bay without cutting in firewall as bay is larger?also will the E15 fit easily on 1980 B-310 GB?
Posted on: 2004/1/7 10:57
STRONG IS STRONGEST ALONE. PERIOD
From GOLD COAST AUZ
Ever thought about tryin to use a 90drg dizy mount of (eg) SUZUKI 1600 VITARA0. [FOOD FOR THOUGHT]
Posted on: 2004/1/7 12:21
rather be a old fart than a young d##khead
From Perth, West Aussie
I just converted a pulsar dizzy for my A15. does anyone have the wiring diagram for this bit? I wanna know if the pulsar coil uses straight 12v or goes thru a resistor.
feral - I also have a van, what did you do about the dizzy / firewall prob?
Posted on: 2004/1/8 4:55
From California
Too bad it isn't like the fwd SR20DE which has a casting for a rwd distributor placement.
(Found this old thread while searching for GA18DE info. There isn't any!)
Oh yeah, please try to slow this 1600 down:
Posted on: 2005/3/30 7:50
converted wrote:
Not quite sure why youd want to use an E15 engine anyway...all sorts of reliability problems
dude, you have a problem with ANYTHING not A series.
E15s are a good engine.
BUT
get the turbo version head. it flows much better than the the NA version.
trust me, we found out the hard-and-often-more-expensive-way.
Posted on: 2005/3/30 8:21
From Perth Western Australia
whats the go with these e series? what cars did they come out in, and did they come out in australia?
edit: just sorta figured (ok, read properly) that they came out in exa's... which years??
Posted on: 2005/6/14 14:57
From ACT
around 83/84 exas. they were the turbo version, which you can also find in the ET pulsar. non turbo engines would b found in the stocko model pulsars that the ET is based on
Posted on: 2005/6/16 11:42
From Albany, NY USA
Well, has anyone ever actually gotten a RWD trans on the back of an E16?
Posted on: 2007/3/10 11:48
« 1 (2) 3 »
