Quick a15 question
From Vanderbijlpark, South Africa
i saw on a thread that the stock a15 can rev 8500 rpm. does is have factory double valve springs or tighter single spings than the a14 or is the cam profile different than the a14?
Posted on: 2010/10/15 8:46
93' Nissan 1400 a15 60a (daily)
82' Datsun 1400 ute (sold)
73' Datsun 1200gx Coupe (sold)
Re: Quick a15 question
From South Africa, Bloemfontein
Not a chance.
The stock A15 have max power at 6000rpm. I bet the stock valve springs can also only handle 6000rpm. It must have been a worked A15 motor.
Posted on: 2010/10/15 11:00
1977 Datsun 1200GX
look at ddgonzal's reply in the a-series newbie thread. he says that a stock a15 short block will rev 8500 rpm
Posted on: 2010/10/15 11:36
From Ringwood, Melbourne, AUS
Yes, short block i.e. bottom end, can probably rev to 8500 but you WILL need good springs on the head and the rest of the gear to get it to turn that high.
Posted on: 2010/10/15 11:57
Deano
thanks for clearing that up. cheers
Posted on: 2010/10/15 13:07
You'd probably also want to add new rod bolts, and arp at that, if you want to play with those sorts of rpms. Often rods themselves can last a long long time, but the bolts themselves (and this isn't specifically a datsun thing by the way)can have a finite life, and the higher the rpm, the shorter that life will be.
We'd also have to add in there that to actually make good power at those sorts of rpms, requires a very well ported head, carefully selected headers (with regard to primary tube diameter, and length and main collector size too) and the sort of carburettion (either a custom plenum and efi, or alternately twin webers/dellortos or efi throttle bodies on an IR manifold. And a pretty serious cam.
And then you'd have to add in that it'd be a pig down in the lower rpm range, have a real thirst for fuel even driven somewhat moderately, etc etc.
So yes, the bottom end is certainly capable of it, but it has to be put in context.
Posted on: 2010/10/15 16:17
John McKenzie
