Re: gx head compression question
From Vanderbijlpark, South Africa
this could be the reason why my gx coupe didnt run all that good, the head was milled and i took another 1mm off the head, had a 1400 bottom end, 1200 flywheel, twin su carbs and a 290 degree camshaft. i don't want the same problem on the ute, i want to build something that will run good on street without problems. so i guess rather just use the same cam, maybe cut a 1200 flywheel and just do bigger valves on the gx head?
Posted on: 2010/10/22 7:30
93' Nissan 1400 a15 60a (daily)
82' Datsun 1400 ute (sold)
73' Datsun 1200gx Coupe (sold)
Subject Poster Date
     gx head compression question RyanFurY 2010/10/20 14:24
       Re: gx head compression question clyons8 2010/10/20 14:54
       Re: gx head compression question ddgonzal 2010/10/21 2:41
         Re: gx head compression question 1200GXman 2010/10/21 7:04
           Re: gx head compression question RyanFurY 2010/10/21 7:49
             Re: gx head compression question aido 2010/10/21 8:59
               Re: gx head compression question Rallytwit 2010/10/21 16:44
                 Re: gx head compression question bakat 2010/10/21 17:29
       Re: gx head compression question ddgonzal 2010/10/22 7:20
         Re: gx head compression question aido 2010/10/22 7:24
         Re: gx head compression question RyanFurY 2010/10/22 7:30
           Re: gx head compression question ddgonzal 2010/10/22 7:52
             Re: gx head compression question RyanFurY 2010/10/22 7:57
       Re: gx head compression question 1200GXman 2010/10/22 10:21
         Re: gx head compression question RyanFurY 2010/10/22 12:35
           Re: gx head compression question 1200GXman 2010/10/22 13:36
             Re: gx head compression question RyanFurY 2010/10/22 13:48
       Re: gx head compression question Rallytwit 2010/10/22 16:52
