Re: 1200 45mm Inserts?
One for the experts...!
An idea I had to maximise travel for the shock would be to not use the tender spring at all, so that the shock has full travel on the actual spring, and won't lose 2-3 inches due to the helper spring?
Of course this would raise the ride height somewhat, but a way around that would be to not use a 1 inch spacer in the bottom of the strut- i.e. have the MK1 insert sitting all the way down in the tube.
Of course this won't ride as nice as Benny's exponential setup, but i'm not too concerned about comfort with my coupe as its not a daily.
Thoughts? Cheers Matt
Posted on: 2010/10/23 4:48
Subject Poster Date
     1200 45mm Inserts? inkjunkie 2010/10/22 10:43
       Re: 1200 45mm Inserts? ssskiwi 2010/10/22 10:54
       Re: 1200 45mm Inserts? levey 2010/10/22 11:01
       Re: 1200 45mm Inserts? MY110 2010/10/22 11:20
         Re: 1200 45mm Inserts? ssskiwi 2010/10/22 11:28
           Re: 1200 45mm Inserts? benny 2010/10/22 12:09
             Re: 1200 45mm Inserts? ssskiwi 2010/10/22 12:30
               Re: 1200 45mm Inserts? benny 2010/10/22 14:37
       Re: 1200 45mm Inserts? MY110 2010/10/22 11:46
       Re: 1200 45mm Inserts? Anonymous 2010/10/22 12:27
         Re: 1200 45mm Inserts? MY110 2010/10/22 12:38
           Re: 1200 45mm Inserts? benny 2010/10/22 14:53
         Re: 1200 45mm Inserts? benny 2010/10/22 14:33
       Re: 1200 45mm Inserts? ssskiwi 2010/10/22 22:27
       Re: 1200 45mm Inserts? inkjunkie 2010/10/23 0:04
       Re: 1200 45mm Inserts? DA75EZ 2010/10/23 0:42
         Re: 1200 45mm Inserts? benny 2010/10/23 1:35
           Re: 1200 45mm Inserts? sideways1 2010/11/21 13:12
       Re: 1200 45mm Inserts? MY110 2010/10/23 4:48
         Re: 1200 45mm Inserts? benny 2010/10/23 6:09
           Re: 1200 45mm Inserts? ssskiwi 2010/10/23 7:57
