Laidlaym wrote:
I have some just got some internals from a 56A five speed, firstly do all 56A five speeds have a 1:1 5th?
Are there only two sets of ratios? Option 1 and Option 2?
Mark
When it comes to the 5 speed 56A gearboxes there is no such thing as 'option 2'
During 1971 & '72 the factory produced two competition versions of the four speed & these were the close ratio 'option 1' and the ultra close ratio 'option 2'[Four speeds]
During 1973 the 5 speed became an option in the GX model & this was simply known as the 5 speed option gearbox. It could also be refered to as the standard 5 speed gearbox. The designation for this box is 5FW56A from memory.
The car that came with this gearbox is commonly refered to as the GX5 these days.
Soon after this the close ratio competition version became available &, like the two four speeds that it replaced, it was available only through the competition department as either a conversion kit of parts for your standard 5 speed, or as a whole transmission assembly.
These were known as the 5FC56A or more commonly as the 'option 1' five speed.
Matto1kUte wrote:
i have a whole b20 diff in the shed if anybody wants to tell me how i tell its ratio.
Do you have a whole differential, or a whole rear axle assembly?
If you have just the whole diff, as you say, then either count the teeth & do a little maths, or alternately, roll the ring gear around untill you can read the numbers that will be stamped into the edge of the ring gear near the teeth. These numbers will be the pinion & ring gear tooth count & you still need to do a little maths.
