smog gear?
From brisbane
i have an a14, and i dont have any smog gear. just wondering if you need it or if its ok to run without it.
Posted on: 2010/10/27 12:03
Re: smog gear?
From Malaysia
you dont need it to run the engine. you need it by the law, if your law says so.
Posted on: 2010/10/27 12:18
Re: smog gear?
From Perth WA AUS
As a basic guide, I'm pretty sure that if the motor did not come with any anti-polution gear and your fitting it in a car of similar age to the motor its all good.
Having said that each state has its own regs
Posted on: 2010/10/27 13:14
Datsun 1200 2Dr sedan.
Re: smog gear?
From brisbane
i think it did because there are two metal tubes at the back of the motor on the passenger side. but there was nothing on there when i bought the car.
Posted on: 2010/10/29 9:25
Re: smog gear?
From Perth WA AUS
On my engine I have one metal tube at the back of the motor on the passenger side that connects to the inlet manifold, and one on the top rear of the rocker cover that goes to the aircleaner normally, although pretty sure my engine came with a pipe that vented the gasses into the atmosphere under the car.
Are they what you are talking about?
Posted on: 2010/10/29 9:43
