Re: A14/15 turbo~280hp, bore question
From Forsby Finland
I have made the same conclusion, 79mm is not a problemeven in a boosted engine, and now I understand why there is 80mm headgaskets available for N/A setups.
I used a tiny IHI RHB5 turbo when i went on the dyno, that´s why hp drops of after 4000rpm! I can put up a vid on the youtube if you wish so!?
D wrote:
Marcus it looks like with 79mm youll have the following measurements
start of bore 1 wall will be 4mm (5.5mm original as in you pics)
siamesed 1 and 2 will be 4mm (7mm original)
while the midle bores will be 3mm each (4.5mm original)
and all side wall around 4.5mm which is where the stress is
Sounds like a 280hp A series with 79mm is going to be perfect!
The dyno figures DDgonzales posted earlier if they are yours? means
your old setup had the most power at 4000rpm and tapered off?
What turbo was it you used if that was your beast?
Posted on: 2010/10/30 8:40
I am building a mean Datsun E10 racer , a15 turbocharged engine, aiming for 280hp....
Subject Poster Date
     A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/9 8:30
       Re: A14/15 turbo~280hp, bore question ddgonzal 2010/9/9 8:40
         Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/9 8:58
           Re: A14/15 turbo~280hp, bore question ddgonzal 2010/9/9 9:06
             Re: A14/15 turbo~280hp, bore question clyons8 2010/9/9 14:57
               Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/9 18:31
                 Re: A14/15 turbo~280hp, bore question reuby_tuesday 2010/9/10 0:11
                   Re: A14/15 turbo~280hp, bore question PIGDOG 2010/9/10 1:17
                     Re: A14/15 turbo~280hp, bore question D 2010/9/10 6:59
                       Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/10 9:46
             Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/9 18:16
         Re: A14/15 turbo~280hp, bore question Dodgeman 2010/9/15 15:06
       Re: A14/15 turbo~280hp, bore question A14force 2010/9/11 0:03
         Re: A14/15 turbo~280hp, bore question Lemonhead 2010/9/11 0:45
           Re: A14/15 turbo~280hp, bore question D 2010/9/11 2:58
             Re: A14/15 turbo~280hp, bore question ddgonzal 2010/9/11 6:16
               Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/14 18:46
           Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/11 7:53
         Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/11 7:27
         Re: A14/15 turbo~280hp, bore question A14force 2010/9/17 7:36
           Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/17 18:20
       Re: A14/15 turbo~280hp, bore question A14force 2010/9/15 6:39
         Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/15 18:30
       Re: A14/15 turbo~280hp, bore question jmac 2010/9/16 8:18
         Re: A14/15 turbo~280hp, bore question reuby_tuesday 2010/9/16 8:40
       Re: A14/15 turbo~280hp, bore question jmac 2010/9/17 7:30
       Re: A14/15 turbo~280hp, bore question D 2010/9/18 3:43
         Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/18 18:22
         Re: A14/15 turbo~280hp, bore question D 2010/9/19 10:55
       Re: A14/15 turbo~280hp, bore question jmac 2010/9/19 11:19
         Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/19 19:47
           Re: A14/15 turbo~280hp, bore question D 2010/9/20 2:12
         Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/23 20:38
       Re: A14/15 turbo~280hp, bore question A14force 2010/9/24 21:51
         Re: A14/15 turbo~280hp, bore question nick_m 2010/9/24 22:12
           Re: A14/15 turbo~280hp, bore question ddgonzal 2010/9/25 2:42
             Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/25 13:23
           Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/25 7:39
             Re: A14/15 turbo~280hp, bore question clyons8 2010/9/25 7:46
         Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/25 7:37
       Re: A14/15 turbo~280hp, bore question rockstardan 2010/9/25 8:37
         Re: A14/15 turbo~280hp, bore question D 2010/9/25 12:13
           Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/25 13:33
             Re: A14/15 turbo~280hp, bore question clyons8 2010/9/25 23:52
               Re: A14/15 turbo~280hp, bore question nick_m 2010/9/26 0:01
         Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/25 13:27
       Re: A14/15 turbo~280hp, bore question clyons8 2010/9/26 0:26
       Re: A14/15 turbo~280hp, bore question jmac 2010/9/27 10:05
         Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/27 19:52
       Re: A14/15 turbo~280hp, bore question jmac 2010/9/28 12:28
         Re: A14/15 turbo~280hp, bore question reuby_tuesday 2010/9/29 0:10
           Re: A14/15 turbo~280hp, bore question D 2010/9/29 1:41
             Re: A14/15 turbo~280hp, bore question ssskiwi 2010/9/29 1:53
               Re: A14/15 turbo~280hp, bore question reuby_tuesday 2010/9/29 2:39
                 Re: A14/15 turbo~280hp, bore question reuby_tuesday 2010/9/29 2:47
       Re: A14/15 turbo~280hp, bore question jmac 2010/9/29 8:05
         Re: A14/15 turbo~280hp, bore question reuby_tuesday 2010/9/29 8:31
           Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/29 11:01
             Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/29 20:38
               Re: A14/15 turbo~280hp, bore question reuby_tuesday 2010/9/29 23:23
                 Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/30 20:17
       Re: A14/15 turbo~280hp, bore question D 2010/9/30 3:26
         Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/30 20:30
           Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/9/30 20:32
       Re: A14/15 turbo~280hp, bore question picko 2010/9/30 9:34
         Re: A14/15 turbo~280hp, bore question reuby_tuesday 2010/9/30 10:11
       Re: A14/15 turbo~280hp, bore question PIGDOG 2010/9/30 11:50
         Re: A14/15 turbo~280hp, bore question reuby_tuesday 2010/9/30 12:50
           Re: A14/15 turbo~280hp, bore question estyre 2010/9/30 13:00
       Re: A14/15 turbo~280hp, bore question nick_m 2010/9/30 12:58
       Re: A14/15 turbo~280hp, bore question picko 2010/9/30 15:13
         Re: A14/15 turbo~280hp, bore question reuby_tuesday 2010/10/1 0:55
       Re: A14/15 turbo~280hp, bore question PIGDOG 2010/10/1 4:25
         Re: A14/15 turbo~280hp, bore question reuby_tuesday 2010/10/1 5:39
           Re: A14/15 turbo~280hp, bore question PIGDOG 2010/10/1 5:54
             Re: A14/15 turbo~280hp, bore question D 2010/10/1 7:05
             Re: A14/15 turbo~280hp, bore question reuby_tuesday 2010/10/1 7:13
         Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/10/1 20:40
           Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/10/1 20:44
             Re: A14/15 turbo~280hp, bore question reuby_tuesday 2010/10/1 23:22
             Re: A14/15 turbo~280hp, bore question Fandatstick 2010/10/2 0:42
               Re: A14/15 turbo~280hp, bore question D 2010/10/2 4:14
                 Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/10/2 8:44
               Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/10/2 8:33
       Re: A14/15 turbo~280hp, bore question A14force 2010/10/3 6:20
         Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/10/3 8:11
           Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/10/3 8:35
       Re: A14/15 turbo~280hp, bore question D 2010/10/3 11:13
         Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/10/4 18:25
       Re: A14/15 turbo~280hp, bore question Lemonhead 2010/10/3 13:03
         Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/10/4 18:34
           Re: A14/15 turbo~280hp, bore question reuby_tuesday 2010/10/5 0:22
       Re: A14/15 turbo~280hp, bore question D 2010/10/7 1:52
         Re: A14/15 turbo~280hp, bore question D 2010/10/11 0:03
           Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/10/12 18:13
             Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/10/26 19:19
               Re: A14/15 turbo~280hp, bore question D 2010/10/27 0:07
                 Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/10/27 19:31
                 Re: A14/15 turbo~280hp, bore question D 2010/10/28 5:40
                   Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/10/30 8:31
           Re: A14/15 turbo~280hp, bore question D 2010/10/15 5:01
       Re: A14/15 turbo~280hp, bore question D 2010/10/30 0:53
         Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/10/30 8:40
           Re: A14/15 turbo~280hp, bore question D 2010/10/30 12:30
             Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2010/11/6 13:46
       Re: A14/15 turbo~280hp, bore question jmac 2010/11/8 8:24
         Re: A14/15 turbo~280hp, bore question clyons8 2010/11/8 9:00
       Re: A14/15 turbo~280hp, bore question Lemonhead 2010/11/8 10:04
         Re: A14/15 turbo~280hp, bore question D 2010/11/8 10:47
           Re: A14/15 turbo~280hp, bore question Lemonhead 2010/11/8 12:21
       Re: A14/15 turbo~280hp, bore question jmac 2010/11/8 12:00
         Re: A14/15 turbo~280hp, bore question clyons8 2010/11/8 12:12
       Re: A14/15 turbo~280hp, bore question D 2010/11/9 5:47
       Re: A14/15 turbo~280hp, bore question jmac 2010/11/15 10:27
         Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2011/4/5 19:43
           Re: A14/15 turbo~280hp, bore question D 2011/4/6 0:31
             Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2011/4/6 18:46
               Re: A14/15 turbo~280hp, bore question D 2011/4/7 0:55
                 Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2011/4/7 5:54
       Re: A14/15 turbo~280hp, bore question dattoman_1000 2011/4/7 1:14
         Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2011/4/7 5:55
       Re: A14/15 turbo~280hp, bore question dattoman_1000 2011/4/7 13:52
         Re: A14/15 turbo~280hp, bore question D 2011/4/7 14:26
           Re: A14/15 turbo~280hp, bore question clyons8 2011/4/7 16:49
         Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2011/4/7 19:53
           Re: A14/15 turbo~280hp, bore question D 2011/4/8 1:12
             Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2011/4/8 19:07
               Re: A14/15 turbo~280hp, bore question Datsun100ATurbo 2011/4/17 16:40
       Re: A14/15 turbo~280hp, bore question roadstar79 2013/7/2 13:00
