Can,t hold back any more.This blue(brushing enamel)wagon was thrown together for use at Ipswich dirt sprints and autocross by yours truly.It would be near on impossable to return it back to the road as too much was removed to be used on other vehicles eg.it has no front wiring loom to headlights,no headlights or carriers,indicators etc.It has no operating alternator and no re charging means it simply runs off a fully charged battery,this was done for convienience at the time as part of the main loom is also missing.It does have a "stock as a rock" A12 engine which was thrown together with rings,bearings and a gasket set,hooked up to a 1000 GEARBOX with very noisy bearings and s/hand clutch.The rear hatch lock is also missing....i removed it for someone on here but was not required and it,s in one of my spares buckets at home.
The car ran mid field in class and was a bit of fun,it was then sold to a good friend of the family for $600.00 used half a dozen times during such time i organized new front shockers and a carby kit,it was then advertised and sold again for $700.00 i believe to the person advertising it as the best thing since sliced bread....far from it,anyway if anyone is keen now you know it,s history if you need more on it let me know via PM
Cheers
