Browsing this Thread:
1 Anonymous Users
Re: Fury's 82' ute build |
From Pretoria SA
Stefano, The std 1400's come with them (almost every one) only the Delux (82-84) and champ (1990-2010) come with too seats.
Riaan, one more thing my 1400 is also a 82-83 model i'm in Danville
Posted on: 2010/10/28 13:16
1400 Turbo
From Vanderbijlpark, South Africa
got the stanza struts in this weekend, unfortunately the brake master decided to start leaking, bought a new one and sent it in for fitment. hopefully that's the last of the braking problems...
Posted on: 2010/11/1 8:36
93' Nissan 1400 a15 60a (daily) 82' Datsun 1400 ute (sold) 73' Datsun 1200gx Coupe (sold)
on the ute
Posted on: 2010/11/1 8:37
did some drifting yesterday and the wiring ended up burning under the dash, through to the engine bay.... fitting new wiring i ordered from nissan this afternoon, got a kit which has the engine bay, dash and rear with all plugs, fuse box and fittings. will get some pics up as soon they deliver. got my flywheel back as well, the best they could do was 7kg's, which is at least better than 11.9 kg.
Posted on: 2010/11/5 7:03
From Pretoria SA
Was the stanza struts an easy fit? they look lekker. Do you have a brake booster?
Posted on: 2010/11/5 7:50
1400 Turbo
the stanza struts was already modief to fit a ute, so it was basically take out old struts and fit stanza ones. i'm not using a brake booster, as soon as you fit a modfied cam your vacume drops and the booster does not work properly. you just learn to step on the brakes if needed.
Posted on: 2010/11/5 7:56
From Pretoria SA
don't know about the cam but it sounds right(std can in mine) anyhow good luk with the rest your up to. Post some pics on your build tread, coun't wait to c Cheers
Posted on: 2010/11/5 9:35
1400 Turbo
got hte wiring done last night, actually very easy since all the plug fit in, got the wiring kit from nissan, one more problem solved and one step closer to getting everything done on the ute
Posted on: 2010/11/6 10:24
From Pretoria SA
Wiring Kit? and coming From nissan wasn't it a bit pricey? Didn't get around to mine don't know when. The diff's keeping me busy.
Posted on: 2010/11/8 8:22
1400 Turbo
got the wiring kit from nissan motordeal here in vdbp, kit includes all plug, fittings and new fuse box. the kit cost me about 1k for the engine bay, under dash & rear.
Posted on: 2010/11/8 10:27
