(1) 2 3 »
A15 Flywheel to A10 engine?
Is it possible to somehow use a late a15 flywheel
on an A10 or am I limited to an early a12 one?
Reason I ask is because since Im using a supercharger
doesnt it make sense to use the extra torque from
idle to help with take off and gear changes?
Posted on: 2010/11/8 11:30
Re: A15 Flywheel to A10 engine?
From Perth WA AUS
I think an A12 flywheel (or maybe A14) would be a good compromise between torque and revability, Just my opinion might be wrong.
Posted on: 2010/11/8 11:38
Datsun 1200 2Dr sedan.
From mandurah
hhmm i was thinking the same thing ,i was going to put a a14 flywheel on my a12 to give it more torque throught the gears and from idle it might work !
and a supercharged A10 thats crazy !! cant wait to see it when done ! got any pics ??
Posted on: 2010/11/8 11:41
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Perth
It won't make more torque
It will just lose less revs thru the gear changes and rev slower
Posted on: 2010/11/8 13:12
From Sydney
Heavy flywheels have the potential to store more energy, the trade off is like what D_1000 said, slower to spin up and slower to decelerate. They are perfect for HWY applications where engine speeds dont vary all that much.
Posted on: 2010/11/8 23:17
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Losing less revs is exactly what Im after and slower to decelerate
means to me it will pull better with its stored energy problem is
which flywheel fits an A10? only early a12?
With a twin V belt pulley off the crank to the alternator, Waterpump
and supercharger it could mayb do with a bit more weight in engine rear.
I drove an old 58 citroen 2cv (640kg) and the thing was so nice to drive with
only 600cc, massive flywheel and 2 cylinders of less than 32hp :)
Posted on: 2010/11/9 4:44
From Sydney
Especially since you only see one power stoke every 360 degrees of crank rotation. The heavy flywheel would certainly help to smooth things out.
Posted on: 2010/11/9 4:55
1970 KB10 Coupe
S13 caliper b...
It helped alright but the unbrella stick shift on the dash
where the radio usually is took some getting used to :)
Posted on: 2010/11/9 5:40
From Perth
ParasolE .... not umbrella
Its French remember
Posted on: 2010/11/9 10:41
wee wee
Posted on: 2010/11/9 12:21
(1) 2 3 »
