no need to cut the tunnel ,if you can get away with using a standard tunnel then life will be heaps easyer when (or if) you need to engineer it
its been done heaps of time without chopping the tunnel
ive found it help if you bolt the crossmember to the motor first then slide it in from the bottom ,that way you can just lift it up and not struggle to clear the steering arm thingo
might be an option ?
good to see this thing is coming along very nicely !
Posted on: 2010/11/20 15:09
77 1200 ute 77mm bore a15 ,12:1 comp ported and reconed h89 head fairly aggro cam ,billet rocker spacers twin 40mm solex carbs on bpro manifold MSD 6al2 with 2 step limiter 4speed 60a box hd clutch 2 inch exhaust locked 4:11 ute diff ...
