#1 A14 flywheel into A12
lcw1980 Posted on: 2010/11/22 3:35
Ok i have a A12 b310 so....
Would it be possible to fit in a lightened A14 flywheel into A12 without any mods? Assuming the clutch and pressure plate is a A12 one? Thanks.
#2 Re: A14 flywheel into A12
LittleFireyOne Posted on: 2010/11/22 4:12
Yes you can fit it, you gotta check the flywheel bolts for premature binding before they're fully tight. I don't remember the specifics of it though, there's another thread around here that mentioned it in regaurds to A12 flywheel on larger A engines
#3 Re: A14 flywheel into A12
lcw1980 Posted on: 2010/11/22 5:38
So that means A14 flywheel can be fitted to A12 engine with no mods right?Quote:
#4 Re: A14 flywheel into A12
levey Posted on: 2010/11/22 10:34
Pretty sure they all fit.
#5 Re: A14 flywheel into A12
estyre Posted on: 2010/11/22 11:42
yeperoo ,they are a direct bolt on i have one bolted onto my a14 bottom end
it all depends on the starter lining up ,but i cant see why it wouldnt :)
good luck
#6 Re: A14 flywheel into A12
levey Posted on: 2010/11/22 11:50
Starter lines up ok.
#7 Re: A14 flywheel into A12
estyre Posted on: 2010/11/22 11:55
thanks nigel ,well it appears it should all work
#8 Re: A14 flywheel into A12
lcw1980 Posted on: 2010/11/23 3:57
ok... I'll change it and see what happens *gulp*
