« 1 ... 4 5 6 (7) 8 9 10 ... 15 »
Re: "WARZ ON" MAD DAT MOTORSPORT DATSUN 1200 UTE updated pix
From Goulburn NSW
Thanks for letting me know about the colour i might get mine painted the same colour.How long did it take you to get it to where you have it now i want to do mine up to have atleast 300hp with a ca18det do u think its worth putting a auto in it
Posted on: 2010/11/18 7:18
From Brisbane
it was built at yatala headworx its running a 3071r turbo microtech computer i cant think of what else was done on it.. before this motor he had a ca18de that he turbod which had 220 rwhp and he said even then it was beating wrxs and cars like that
edit. if your talking about the gearbox i can ask him and get back to you if you want?
Posted on: 2010/11/18 8:35
From brisbane. waking up the neighbours with the brap
Dude there is a million colours out there to choose from. I'd rather you didn't go the same as mine. I have had the car for about 8 months. If the car was still for street I would have a manual.
Niz12 I see your car all the time. If you ever see a random guy in a white hilux waving it's me. Lol
Posted on: 2010/11/19 2:34
13b turbo datsun 1200 ute. (WARZ ON)
www.maddat.com.au
From Goulburn NSW
I realy like the colour but i shall grant your wish and not get mine painted the same
Posted on: 2010/11/19 4:53
From Goulburn NSW
Dude what wheel off set are you running i am eventually getting the front end parts from mad dat
Posted on: 2010/11/19 6:10
2 5/16 backspace on a 4 inch rim. Scott set me up with a different ball joint to bring the wheel in a bit. You will need adjustable control arms and top hats. Speak to him about the kit tho. The brakes are awesome. Pulls up nice strait and quick.
If you are looking for a cool colour check out the new ford focus rs. The is a wild new green colour that would be different and look mint.
Posted on: 2010/11/19 8:12
www.maddat.com.au
From Sydney
if i were you.. talk to a enginner and get him to email you all the requirments needed for conversion,
The max engine size (forced induction) that is permitted (By RTA regulations) to be fitted is 1825cc.
That said I would be very suprised if the 1200 ute chassis could be made suitable for a 1.8 litre turbo engine. The low rear axle weight means that pretty well regardless what you do to rear suspension there will be traction and hence stability issues.
If it could be done it would be very involved and expensive. I imagine the chassis will need stiffening, rear suspension axle location would need significant improvement. Front will require re rating of springs and dampers. The standard brakes would be far from satisfactory.
Depending on the year of the ute the testing required to demonstrate compliance would be substantial and expensive. And at the end of the day the answer might be that it is not satisfactory...
An A15 with a GX head and a simple brake upgrade would be a much easier mod.
Regards,
this is from a enginner him self
Posted on: 2010/11/19 10:15
From Goulburn NSW
I checked out the colour its not bad.Have you seen the new commadore green its a bit darker
Posted on: 2010/11/19 10:16
From Brisbane
oh really where have you seen me ? you should bring your datto round n take me for a spin? :P i could take you to my mates and show you his gearbox setup . he said u can get a kit from mv automatics in sydney that manualise it and you just need to wire it up. he is running a 3000 stall on his
Posted on: 2010/11/19 11:11
From Goulburn NSW
Hi how are u if i go 1 3/4"on a 4" wheel will that put them further in again
Posted on: 2010/11/22 9:10
