Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#11
Re: A15 Race engine tips
bige
Posted on: 2010/11/20 11:30
all of the after market heads are designed with a very high roof in the ports. this allows the so called short turn to have a lot larger radius, which makes the head flow alot better, the ports are all about raising them,and making the short turn less of a right angle turn.the problem with a series ,is that you often you hit water when raising port.takes lots of time ,welding and experience to get it right.lots of power is made by the head and a number of other things. a good engine, is a combo of a everything.to many to list.(been there done that) cheers ernie
#12
D
Posted on: 2010/11/20 19:51
love this!!!
Attach file: rc.jpg (37.50 KB)![]()
#13
Cherryx-1
Posted on: 2010/11/21 19:39
Good you like, thanks. I was thinking that is there any thought that i fit some another car tecknics in that little car?? And what that can be?
T:kimmo
#14
Cherryx-1
Posted on: 2010/11/21 22:18
Is there any help use roller rockers?
#15
E10
Posted on: 2010/11/21 22:57
Nice car you have there.I have not been racing mine for three years now,it is about time I start putting it back together (when I think about it that is when I bought and started restoring my 1200,now that I am driving it the interest in racing has somewhat vanished,or maybe it is age?).Can you give some more details about your car,like what you have for brakes,suspension,gearbox?
#16
Wombat_racing
Posted on: 2010/11/21 23:14
I think we should start an E10 race/fast car topic on here. I want to know more about all these E10's and there set ups.
#17
Rallytwit
Posted on: 2010/11/21 23:21
I think just going to a more stout connecting rod, carillo etc., in conjunction with your existing specs should work well. Roller rockers will help eliminate some frictional losses.
What rulebook do you have to stick to? FIA spec, local group etc. The A=series build is well documented: In the U.S. A-series engines use the race/GX head with bigger valves, 14-1 compression, .495 lift with 300 degrees duration camshaft, Weber DCOE carbs (40mm or bigger), roller rockers, crank fire ignition, dry sump & 7lb flywheel. This makes 100HP at the wheels for an A12. If you're only restriction is a stock block then you could do some radical things like configuring the port angle. I'l also curious about what gearbox, etc. is in your car..........are there close ratio boxes availible for FWD as well as limited slip diffs? Tom
#18
Wombat_racing
Posted on: 2010/11/21 23:39
Mine only has a standard N10 pulsar 5 speed gearbox there was other gear sets originally made for the factory race cars and an LSD (rare as rocking horse poo). Mine is to be used for hillclimbs motokhana's and maybe a track day or two.
#19
Cherryx-1
Posted on: 2010/11/22 11:56
I have mazda 323 front brakes and disk, rear vw golf brake and disk. Spax dampers, cherry n10 5 speed gearbox, toyota starlet limited slipp diff, gearbox is modifield for race. Engine have megasquit fuel injection.
t:kimmo
#20
Wombat_racing
Posted on: 2010/11/22 19:30
I have stared an E10 thread if you want to post some more pics or information in there.
http://datsun1200.com/modules/newbb/v ... id=347048#forumpost347048 You can view topic.
