(1) 2 3 »
R31 Diff questions
From Mandurah, Western Australia
Well the R31 diff is in the coupe and on first drive I am happy with the Ratio.
But man does the bloody thing whine. If you think your wife is bad you aint heard nothing till you have heard this diff.
Noise starts off at reasonable level at 50 and when you get to 80. "Your looking for the ear plugs"
So I gues the question is can these things be re-built? I know they were notorious in the Skylines, even under warranty for diff whine but this is way worse. The diff in question has 400,000 km on it too. Also the housing after a drive is quite hot to the point of not being able to hold your hand on it. Is this normal?
I guess if I go rebuild I might as well look into LSD?
Cheers
Posted on: 2010/11/24 13:08
Re: R31 Diff questions
From Perth WA AUS
Sounds like it's nearly rooted.
Posted on: 2010/11/24 13:13
Datsun 1200 2Dr sedan.
From Perth
Put some oil in it
4.11's were noisy
Yes they can be rebuilt
And if you have a 28 spline one as its the same as Commodore internals you can get spools, lsd's, blah blah
Posted on: 2010/11/24 13:18
Nah its not rooted it still works
But looking at the re-build kits you only get the bearings, pre-load washer and oil seals. So dont know if that will stop the whine.
Could get whole guts swapped as already got axles to suit and the housing modified. Just need someone to do it for me.
Interested to hear from others who have the R31 setup.
Posted on: 2010/11/24 13:20
From mandurah
pm sent
Posted on: 2010/11/24 13:24
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
pm ???
Yes it has oil and I know the 3.89 diff is prone to being noisy.
Might ring WA diff center tomorrow and get some more info.
Posted on: 2010/11/24 13:28
From Perth
Grab your ankles
And bring some lube
Posted on: 2010/11/24 14:41
From mandurah
damn it neil....... the ankles bit reassures that it involves anal sex
Posted on: 2010/11/24 15:07
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
From Gold Coast
sounds a bit like it needs the backlash set, the tolerance is too tight producing heat and the noise.
But you said it has 400,000km on it, so the backlash should be getting bigger if anything lol.. im not sure
Posted on: 2010/11/24 20:35
From Sydney, Australia
I'd pop the back cover off, pop the axles and remove and measure the shims that are either side of the diff centre. The diff builder probably put the shims in the wrong way.
But if it's an old diff, then anything is possible. Maybe the housing wasn't welded up square when they shortened it.
Posted on: 2010/11/24 22:17
(1) 2 3 »
