Coupe 1973 rear wheel bearing inner 32 mm
Hi,
I'm after two rear wheel bearings 1200 coupe 1973. Inner size needs to be 32mm and outer size 62mm. Who has two bearings or has solved it in another way, the bearing replacement?
It is for a project car, A14 5 shift, 128,3 BHP dyno run...
Posted on: 2010/11/27 12:11
Re: Coupe 1973 rear wheel bearing inner 32 mm
From Perth
K2845 wheel bearing kits (Timken industry number)
K2845
B32-3CC5 32 x 62 x 16 Bearing
R32J(08-R1) 31.98 x 41 x 21 Collar Ring
400413N 41 x 56 x 7 Seal
Posted on: 2010/11/27 12:34
Hi,
Thanks for the info,
Posted on: 2010/11/27 14:43
