Engineering required for 5-speed in VIC?
Anyone know if VicRoads needs to be notified of a modification (and VASS certificate etc ) if you install a 5-speed in a 120y?
Posted on: 2010/12/6 6:55
Re: Engineering required for 5-speed in VIC?
From Geelong
do you really need to? essentially its the same box, with different cogs. swapping a t50 or something different in probably would
Posted on: 2010/12/6 8:49
From Ballarat Victoria
Technically, It would need an engineers tick if it had a non standard gearbox crossmember.
If it was neatly made and painted i`d be surprised if any roadworthy certification place would pick up on it.
I personaly would fit it and say nothing. You`d be mad to do anything else!!
Posted on: 2010/12/6 9:12
From Perth WA AUS
Yep. Make it look stock and see how you go from there, that what I'm doing.
Posted on: 2010/12/6 9:38
Datsun 1200 2Dr sedan.
From Ringwood, Melbourne, AUS
A roadworthy inspection cannot fail you for a mod if it is safe and properly executed, the following is from the VicRoads Roadworthiness document:
"In these circumstances an examination should be confined to checking that the modification appears to be properly executed and not in a condition which presents a hazard."
And:
"A VASS approval certificate should only be requested by a Licensed Vehicle Tester, when a vehicle modification,
which affects handling, structural integrity or compliance with the standards for registration, does not appear to comply with good industry practices."
See here: http://www.vicroads.vic.gov.au/NR/rdo ... C7816777A3/0/VSI26web.pdf
Posted on: 2010/12/6 10:07
Deano
Also see VSI 8 section 3 for approved mods that do not require certification:
http://www.vicroads.vic.gov.au/NR/rdo ... 1-3BD72EF88340/0/VSI8.pdf
Posted on: 2010/12/6 10:20
Deano
unless you have to cut and weld in a section of the trans tunnel, it's unlikely it will ever come up.
I remember as a teen helping a mate with a car, we made our own crossmember (and it was a very rough piece of work to say the least) and a roadworthy tester knocked it back. But it was really bad - I honestly think someone could have made a better one with pieces of wood, glued together with flour and water.
Posted on: 2010/12/6 12:25
John McKenzie
I remember reading about a guy who installed a celica 5 speed in a holden and felt that he didn't need a crossmember so he put a brick in between the firewall and rear of engine. It was going fine until he hit a bump and the brick fell out. You can imagine what happened next.
Posted on: 2010/12/6 22:03
