« 1 (2)
Re: For those of you who are always wanting a bigger engine...
From Perth WA AUS
Posted on: 2010/12/8 8:59
Datsun 1200 2Dr sedan.
From Coondle, WA Australia
When i worked at the Perserverance UG operation in leinster, the old power station used 6 Wartzilla diesel generators that were similar size. They used to be the primary power supply until a Gas Turbine (GT) unit was installed some time ago.
May when they run, the plume of diesel smoke is amazing. Its about 4 foot wide and goes straight up for about 10m, and its a solid black column.
When they ran them ( not often anymore) we used to get emegrency calls of people thinging a fire had started in the Power plant. I wish i had got more photos than I did.
Those units were about 3 stories. Two above ground with an acess level basement that they sat in.
Posted on: 2010/12/8 23:11
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From northern 'burbs adelaide
imagine the power if they could get 200 rpm hahahaha
Posted on: 2011/1/11 9:52
Quite a regular
From Sydney NSW
Should chirp the tires.
Posted on: 2011/1/11 21:26
« 1 (2)
