« 1 (2)
#11 Re: For those of you who are always wanting a bigger engine...
levey Posted on: 2010/12/8 8:59
#12 Re: For those of you who are always wanting a bigger engine...
reuby_tuesday Posted on: 2010/12/8 23:11
When i worked at the Perserverance UG operation in leinster, the old power station used 6 Wartzilla diesel generators that were similar size. They used to be the primary power supply until a Gas Turbine (GT) unit was installed some time ago.
May when they run, the plume of diesel smoke is amazing. Its about 4 foot wide and goes straight up for about 10m, and its a solid black column.
When they ran them ( not often anymore) we used to get emegrency calls of people thinging a fire had started in the Power plant. I wish i had got more photos than I did.
Those units were about 3 stories. Two above ground with an acess level basement that they sat in.
#13 Re: For those of you who are always wanting a bigger engine...
aidaniel Posted on: 2011/1/11 9:52
imagine the power if they could get 200 rpm hahahaha
#14 Re: For those of you who are always wanting a bigger engine...
Stinky Posted on: 2011/1/11 21:26
Should chirp the tires.
« 1 (2)
