Browsing this Thread:
1 Anonymous Users
Z series conversion |
From Rosewood, QLD
has anyone done say a Z24 conversion into a 1200?
im tossing up some ideas for relatively cheap conversions comparitively with finding an A series 5 speed, most 5 speeds are around the $1200 mark with possibly a million kms on it and needing a rebuild costing a similar amount.
over the last few months i have also observed several CA18DE's with gearbox, lume and ECU sold for under the price of an A series 5 speed.
the E15 definitely catches my eye and they are very cheap, lightweight and factory turbo but then there is gearbox issues as well, would have to get a bellhousing converted to something like a CA box and im guessing that would be expensive.
the L series motors and 5 speeds are cheap but getting old and racking up the kms.
so im thinking maybe the Z series from D21 navaras and pathfinders would be the go, super reliable and tourquey and parts are still readily available, im just not sure about the dimentions of the motor and box and if there would be any firewall/transtunnel mods needed.
any ideas guys?
Posted on: 2010/12/16 1:31
1971 B110 sedan project. 2012 Nissan Micra daily.
Re: Z series conversion |
From Geelong, Vic
same as fiting an L series, block and gearbox and pretty much the same. they lean the oposite way to L series to accomodate the inlet manifold. NA, carby, form you are probably better going an L series as there are more parts available and most Zs are as old as L20b and such anyway
efi or turbo form you are probably better off going CA as the injection and turbo stuff is alot easier to get CAs as also smaller and easier to fit in than both Z and L
not much point thinking and E series if you are doing the conversion to get a 5 speed as you are no better off then the A series
in my opinion the best option would be to find a running CA, one that you can actually see running not one that was "running" before it was pulled out for an SR conversion.
oh and for any of those engines i would count on tunnel work unless its auto, as all the gearboxes are about the same size
Posted on: 2010/12/16 4:23
Whitesedan has done the Z in his 1200 sedan, I think he has twin webers as well. He doesn't come online though, I can give you his number.
Chris
Posted on: 2010/12/16 4:28
From Geelong, Vic
he has L series in both his 1200 sedans
he has a z24 in his 180b though
Posted on: 2010/12/16 4:30
From Vancouver, Wa
Posted on: 2010/12/16 5:55
1969 Datsun 1000 (B10) 1972 Datsun 1200 coupe (ADVAN) 1981 Datsun 210(B310) 4-door (sr20det) 1971 Datsun 1200 (sedan)
From Rosewood, QLD
cheers guys, the CA is sounding pretty good especially with the ability to use factory turbo gear down the line if i choose to go that far, plus there should be some local drift kids wanting to dump CA gear.
Posted on: 2010/12/16 7:33
From mandurah
whats a running CA18DET worth with a box ,harness ,computer and all ??
Posted on: 2010/12/16 9:17
77 1200 ute 77mm bore a15 ,12:1 comp ported and reconed h89 head fairly aggro cam ,billet rocker spacers twin 40mm solex carbs on bpro manifold MSD 6al2 with 2 step limiter 4speed 60a box hd clutch 2 inch exhaust locked 4:11 ute diff ...
From Townsville, Qld
depends who your mates with, mabey 900 bucks with said mates..
Posted on: 2010/12/16 9:20
From Rosewood, QLD
yeah there are times when a complete front cut will cost less then a grand, but yeah ive seen 3 go for around the $900 mark thats why im having difficulty justifying spending $1400 on a worn out old 5 speed.
Posted on: 2010/12/16 9:29
Bugger CA go for something different, like an A-Series.
Posted on: 2010/12/16 9:36
