Sparking problrm
From Wellington
Anyone help here, i have power to the coil but no spark from the coil, the coil is new .....its an a15. , thanks in advance...Jas
Posted on: 2010/12/20 0:04
Re: Sparking problrm
From Ballarat Victoria
Are the points set properly?
Turn IGN on and try opening/closing the points with a screwdriver whilst holding the coil HT lead near the block/earth. The spark should jump to earth as the points open.
Check ign 12v to coil pos. coil neg to points/condensor
You can also check for points opening and closing while cranking with dissy cap off. you should see a very small spark between the points as they open.
Dwell on a 4 cyl is normally set between 48- 50 deg. if you have accses to a meter.
Posted on: 2010/12/20 1:19
From Wellington
Yep, we checked all that yesterday.....I have no access to a metre...
Posted on: 2010/12/20 1:57
From Malaysia
Tried checking the the contact probe at the back of the distributor cap?
Its a spring loaded carbon probe which touches the center of the distributor arm.
The probe normally gets stuck to the top of the cap & this prevents current flow to the distributor arm...
Posted on: 2010/12/20 2:35
Datsun Malaysia
From Wellington
Thanks G1, i,ll look for it tonight
Posted on: 2010/12/20 3:14
From Wellington
ok, just got a spark off the screwdriver when opening the points, is this good or bad?
Posted on: 2010/12/20 5:30
