Re: Chattering noise from rocker assembly........the tappet clearances are all good, help?
From Kyoto Japan
what engine oil are you running?
Posted on: 2010/12/20 7:59
guard mirrors, whitewalls.....life's almost complete.
Club Sunny Truck - REPRESENT!
Hayashi Racing
Secret Factory Japan
Subject Poster Date
     Chattering noise from rocker assembly........the tappet clearances are all good, help? clyons8 2010/12/19 6:44
       Re: Chattering noise from rocker assembly........the tappet clearances are all good, help? teretonga 2010/12/19 6:50
         Re: Chattering noise from rocker assembly........the tappet clearances are all good, help? clyons8 2010/12/19 7:07
           Re: Chattering noise from rocker assembly........the tappet clearances are all good, help? ssskiwi 2010/12/19 7:15
             Re: Chattering noise from rocker assembly........the tappet clearances are all good, help? clyons8 2010/12/19 10:22
               Re: Chattering noise from rocker assembly........the tappet clearances are all good, help? ssskiwi 2010/12/19 10:37
                 Re: Chattering noise from rocker assembly........the tappet clearances are all good, help? clyons8 2010/12/19 10:52
                   Re: Chattering noise from rocker assembly........the tappet clearances are all good, help? ssskiwi 2010/12/19 11:07
                     Re: Chattering noise from rocker assembly........the tappet clearances are all good, help? clyons8 2010/12/19 11:14
       Re: Chattering noise from rocker assembly........the tappet clearances are all good, help? bakat 2010/12/19 12:09
         Re: Chattering noise from rocker assembly........the tappet clearances are all good, help? ssskiwi 2010/12/19 21:58
       Re: Chattering noise from rocker assembly........the tappet clearances are all good, help? estyre 2010/12/19 23:22
       Re: Chattering noise from rocker assembly........the tappet clearances are all good, help? bert 2010/12/20 6:07
         Re: Chattering noise from rocker assembly........the tappet clearances are all good, help? clyons8 2010/12/20 7:54
           Re: Chattering noise from rocker assembly........the tappet clearances are all good, help? DISCO_BOB 2010/12/20 7:59
             Re: Chattering noise from rocker assembly........the tappet clearances are all good, help? clyons8 2010/12/20 8:09
       Re: Chattering noise from rocker assembly........the tappet clearances are all good, help? levey 2010/12/20 8:11
       Re: Chattering noise from rocker assembly........the tappet clearances are all good, help? clyons8 2010/12/20 22:37
       Re: Chattering noise from rocker assembly........the tappet clearances are all good, help? bert 2010/12/20 23:03
         Re: Chattering noise from rocker assembly........the tappet clearances are all good, help? clyons8 2010/12/20 23:18
       Re: Chattering noise from rocker assembly........the tappet clearances are all good, help? jmac 2010/12/21 2:18
         Re: Chattering noise from rocker assembly........the tappet clearances are all good, help? clyons8 2010/12/21 2:31
           Re: Chattering noise from rocker assembly........the tappet clearances are all good, help? clyons8 2010/12/21 9:54
       Re: Chattering noise from rocker assembly........the tappet clearances are all good, help? clyons8 2010/12/23 23:09
       Re: Chattering noise from rocker assembly........the tappet clearances are all good, help? clyons8 2010/12/25 1:28
         Re: Chattering noise from rocker assembly........the tappet clearances are all good, help? levey 2010/12/25 2:08
           Re: Chattering noise from rocker assembly........the tappet clearances are all good, help? olboy 2010/12/25 5:49
             Re: Chattering noise from rocker assembly........the tappet clearances are all good, help? tommo73 2010/12/25 6:21
               Re: Chattering noise from rocker assembly........the tappet clearances are all good, help? clyons8 2010/12/25 6:49
                 Re: Chattering noise from rocker assembly........the tappet clearances are all good, help? clyons8 2010/12/25 6:53
                   Re: Chattering noise from rocker assembly........the tappet clearances are all good, help? tommo73 2010/12/25 7:11
       Re: Chattering noise from rocker assembly........the tappet clearances are all good, help? bakat 2010/12/25 14:21
         Re: Chattering noise from rocker assembly........the tappet clearances are all good, help? clyons8 2010/12/25 21:32
       Re: Chattering noise from rocker assembly........the tappet clearances are all good, help? DISCO_BOB 2010/12/27 13:14
       Re: Chattering noise from rocker assembly........the tappet clearances are all good, help? clyons8 2010/12/29 11:04
       Re: Chattering noise from rocker assembly........the tappet clearances are all good, help? LittleFireyOne 2010/12/31 5:04
         Re: Chattering noise from rocker assembly........the tappet clearances are all good, help? clyons8 2010/12/31 6:05
           Re: Chattering noise from rocker assembly........the tappet clearances are all good, help? tommo73 2010/12/31 8:50
             Re: Chattering noise from rocker assembly........the tappet clearances are all good, help? clyons8 2010/12/31 8:54
               Re: Chattering noise from rocker assembly........the tappet clearances are all good, help? tommo73 2010/12/31 9:30
