Re: Reverse switch success!!
From Seattle ,WA.
Congrats, Very creative!
if you have any pic's I'd be quite interested in the end result. I was looking into this a little while back as I was dry fitting my 60A into the coupe so I could make the trans mount adapter & realized what a pain the rev switch was.
when I had the trans apart for rebuilding I thought (cant remember for sure) the end of the rod had a carrier bushing/bearing pressed in the housing so the shaft wouldn't wear the housing. What'd you do to deal with that, drill thru it or whats actually there?
look forward to seeing this as a how to post.
thanks, evan
Posted on: 2010/12/12 17:25
From Perth WA AUS
This mod really needs to go on wiki :)
Posted on: 2010/12/14 10:17
Datsun 1200 2Dr sedan.
From Fremantle, West Australia
will do but first I want to try it on my 60A box
cannot see there being any problems but tat could be famous last word-- stay tuned
Posted on: 2010/12/14 11:12
update
managed to split my 60A box tonight
successfully drilled a pilot hole and enlarged it to 6mm but now I am stuck because I need a longer 8.5mm bit.
I need the extra length because the chuck of my drill hits the extension housing and stops me from drilling a vertical hole.
Hopefully I can get hold of another drill bit in the next few days.
Looks like there is plenty of aluminium thickness to tap into so this time I wont bother with the metal putty
Posted on: 2010/12/14 12:52
Drilled my 8.5mm hole and tapped the thread, fitted the switch and it works!
Just need to sort out a relay so that the rev light comes on in reverse instead of neutral and all forward gears
Posted on: 2010/12/21 3:34
FAILED FAILED FAILED
The whole plan is fatally flawed
I had not considered the rev/5th selector rod moves backwards into the recess (when in 5th) where I had installed the new switch
Naturally I am very embarrassed and will probably win "Knuckle Head of the Year" award
AAAAGGHHHH
Posted on: 2010/12/21 8:10
From Castro Valley,CA USA
LOL! Install an "O/D" light in your dash!
Posted on: 2010/12/21 8:59
From Perth WA AUS
Your doing a great job Mal, if not you who else would be putting in the hard work with this problem?
Well done I say And I'm sure you will get it sorted.
Posted on: 2010/12/21 9:32
Thanks Levey
the 40mm hole in the tunnel is probably the way to go.
I have seen it done covered with a neat rubber grommet
Posted on: 2010/12/21 9:43
From Freo
Uncle Mal.. always on a quest...
Posted on: 2010/12/21 10:20
A15 PSI Project Motor
'72 CB750k,
« 1 (2) 3 4 5 »
