circuit guys / high powered guys
From Brisbane
Hey guys
I'll shortly be looking for a couple of decent rear tyres for the 120y.
local (aust) purchase from a shop
205/14, in a race compound.
may go wider, possibly up to 225 but won't know til my diff is in
may consider drag radials if there's anything available in 14" locally
Can anyone let me know the current options in R-compound or similar?
Posted on: 2011/1/4 3:44
Re: circuit guys / high powered guys
From gold coast QLD.
Tyretech in Brisbane for R Spec.
Yokys 175,185,195/60-14,fairly sure they do a 205 and 225 also but not on my list.
Toyos 205/55-14,225/50-14
Rough round figures about $230 per corner
Cheers
Posted on: 2011/1/4 6:20
From Brisbane
Great!
Any thoughts on any of the models in particular? Really only interested in accelerative grip, although a tyre that lasts a decent amount of time in everyday driving would be nice.
Posted on: 2011/1/4 10:04
From brisbane
Hi Leigh given your intended usage will lean more towards drags than circuit I would suggest you buy some really good drag radials for the rear.
You can then pick up some cheap second hand semi slicks if you do decide to track the car. For example I recently bought some near new 205/50/15 KU36 semis for $350.
If this isn't suitable I don't think you can go past the Toyo R888 for bang for buck.
Posted on: 2011/1/4 10:07
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
From brisbane
I have NFI when it comes to drag radials but 14" is a bit of an orphan when it comes to circuit rubber. Most brands only offer a 185/60 or 195/60 but the Toyo R888 is available in 225/50/14 and 205/55/14.
Hornibrook Motorsport is where Sam and I get tyres from.
Posted on: 2011/1/4 10:32
From Christchurch NZ
Drag radials aren't an ideal tyre for street use. They'll wear out stupidy quick. If you want to drag race, you're better off having a spare pair of wheels that you can fit at the track.
Posted on: 2011/1/4 21:19
Forced Induction!
From Brisbane
I was impresed when I borrowed your 888s, Matt. I think they were 205s, not sure though as it was quite a while back now. I think they would double fairly well as a street/strip tyre, drag radials are a bit unrealistic for a car that is 95%+ used on the road.
Posted on: 2011/1/4 23:34
From brisbane
Sorry Leigh for some reason I thought you already had decent street rubber and this was more for competition.
The R888s will be fine for a combination of street, drag and circuit. I have driven on the them in the rain many times and they are OK as long as you are careful, however they are not as good as a traditional street tyre for wet conditions.
The ones you borrowed from me were 205/50/15.
Posted on: 2011/1/4 23:39
From Brisbane
great
ballpark on what kinda $ they were?
Posted on: 2011/1/5 0:15
From brisbane
From memory they were around $280-$290 a corner from Hornibrook.
I think I paid around $1100 for the set as the front 195s are a bit cheaper.
Posted on: 2011/1/5 11:06
