Re: removing rust
From ashtonfeild maitland nsw
can u sand blast yourself or do u need to get somone to do it
Posted on: 2011/1/3 7:36
Re: removing rust
From Seattle ,WA.
there are mobile guys w/trailers setup for blasting on site, check into those. it'd be so much easier & faster - ask me how I know
did my entire car inside & out with a DA & stripper - gob's of work!
Posted on: 2011/1/3 16:48
Re: removing rust
From Sydney
rust is just like cancer you can treat it now n be no signs for a while but it will always return one way or another..
if its like you said surface rust just sand off the surface back to full bare metal n finish it of nice n smooth 240 grit or 400 grit sand paper with 4 coats of HS ( high solid primer ) make sure its 4 parts to 1 when mixing so its got a build up of primer...
Posted on: 2011/1/3 21:19
Re: removing rust
i just got 2 qouts for sandblasting one was 2500 and the other was 1200 what a rip
Posted on: 2011/1/3 23:32
datsun or girlfriend ?hard choice
Re: removing rust
From Brisbane
I got a price of $900 to sand & prime my Hilux ute cab only so those prices aren't far off.
When you consider how much time it will save you, $1200 isn't bad at all!!
Posted on: 2011/1/4 0:26
Re: removing rust
i might do it mydelf then lol
Posted on: 2011/1/4 0:37
Re: removing rust
From Seattle ,WA.
What did you use on the panels, got a link to the product? Most likely you're OK if you can neutralize it properly prior to coating it w/anything, primer, epoxy, paint, bondo, etc...
figure out what it is & how to wash it off properly then sand down the metal again, you dont want to grind any of it into the metal. Some of that stuff you can neutralize w/just water just dont put anything on top of it till you've cleaned it properly - the same goes for chemical strippers as well, they just need to be throughly cleaned.
Posted on: 2011/1/4 2:34
Re: removing rust
working on getting name and link for u
Posted on: 2011/1/6 8:42
Re: removing rust
btw it says its a primer aswell
Re: removing rust
hey here is a link to the product its called 3m k&h rust converter and primer
http://www.google.com.au/url?sa=t&sou ... obrAF02_s5WBqp2BlMGv3iSGQ
Posted on: 2011/1/9 3:37
« 1 (2) 3 »
