« 1 2 (3)
Re: h/p per ton
From ACT
The damaged RB30 180B I recently bought is 1100kgs on the engineers report and thats in full street trim with the bigger brakes and diff required so almost silvia territory but with an extra Litre and potential to drop a fair few kgs of interior.
Makes me think whack a turbo on the side, strip the interior and put in a cage for some stupid amounts of track fun.
Say 150kw for a Vl Turbo motor
thats 182.8hp/ton, mmmmmm yummy!!
Posted on: 2011/1/13 0:45
Now riding dirtbikes:
Lots of A series Datto stuff for sale
Re: h/p per ton
From Ballarat Victoria
It would be cool if people list their dattos HP/Tonne figures..
Probably too much to ask as most people wouldnt know their car`s weight. but could be interesting.
Just use Datsss`s basic formula.
1000/cars weight x HP= ????
I used the formula to work out how much power i would need to compete with the others on the grid.... Scary!
RX7 950kg/290Hp =305 HP/T
Comm 1350kg/550Hp =407 HP/T
The Datto would need to make 285Hp to be up with the Commodore. Im about 135 short...bugger!
Posted on: 2011/1/13 0:56
VIC DYNO HIRE
Re: h/p per ton
From perth airport
dude sr20 with 2871 turbo will be eazy around the 350hp mark with stock motor just injectors and niztune :D that give 437.5hp/t
Posted on: 2011/1/13 1:37
perth airport parking
Datsun 1200 ute A14
Re: h/p per ton
Ive built it for the under 2lts class, was hoping to be in the top 10 outright. I`ll try with the Turbo A series and get as much weight out as i legally can.
It`ll end up about 300 Kg/T once sorted.
Your def right tho, Cossie55(member on here) runs a SR 20 in the over 2 lts class and makes Big HP! Im looking forward to seeing him up the pointy end.
Posted on: 2011/1/13 2:01
VIC DYNO HIRE
Re: h/p per ton
From Wellington
The good thing about it also is that the more h/p you have to start with the greater the gain after weight loss.
Lets say you fit a super charger to the a15 and its got 180 flywheel h/p and 125rwhp
1000/700=1.428x180= 257.1 h/p per ton
and after weight loss
1000/634.5=1.576x180= 283.68
283.68- 257.1 = 26.58 flywheel h/p per ton
Wow thats double the from the first example....
Posted on: 2011/1/13 8:49
Re: h/p per ton
From brisbane
OK for my 1200 the numbers are:
183rwkw = 245rwhp
Working off an estimated 20% driveline loss = 294 at the flywheel.
Estimated weight is 900kg. I am yet to have the car on a calibrated weighbridge.
1000/900 = 1.111 x 294 = 326HP/tonne
Posted on: 2011/1/13 9:21
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
Re: h/p per ton
From Perth WA AUS
EDIT: I'm looking at 182.85hp/tonne :(
Posted on: 2011/1/13 9:28
Datsun 1200 2Dr sedan.
« 1 2 (3)
