#1 Single Side Draught
Buff Posted on: 2004/1/20 4:38
How many of you guys out there are running a Single Side Draught as opposed to a set of twins.
What sort of performance / happy / not happy???
I'm building a strong little A15 and I'm thinking of running a single or maybe even running with a 32/36 Downdraught - just to keep the cost down initially - even just to run the engine in.
How Available are Single sidies & manifolds for the a series & $$$
Thanx for any input.
#2 Re: Single Side Draught
1200rallycar Posted on: 2004/1/20 5:01
knew someone who had a single sidie, he upgarded to twins though, "nuff said"
mind you i think the 32/36 is a good road car option, and is gonna be STACKS cheaper than setting up a single sidie
#3 Re: Single Side Draught
Buff Posted on: 2004/1/20 5:14
Yeah, I'm not tied up with the whole bigger is better thing.
It will be for a strong A15 street motor with full headwork, decent cam, fully balanced etc, oversize pistons(Not Forgies) etc etc.
I can't see any reason for a properly set up 32/36 to do the job - even for a while as I said to run it in even - then if the needs there go for the twins.
What sort of figures do reckon I'd be looking at with the above said mods?
#4 Re: Single Side Draught
1200rallycar Posted on: 2004/1/20 5:21
NFI really, over 100hp at fly should be easy, could depend on carburation a bit
bigger is GENERALLY better at higher revs (dodgeman is gonna grill me for that), if you go for twin sidies you will get more power up top and therefore a higher maximum hp reading, but the low end could be sacraficed compared to a single side or downdraught
it really depends how its setup also
in honesty without mates rates or special deals, a 32/36 will set you back $250-300
twin sidies $800-1200 depending if you buy it semi setup for your motor and with manifolds, linkages, trumpets and socks or not
(prices includes parts, tunning ect ect, i.e. fully setup and running from scratch)
#5 Re: Single Side Draught
Buff Posted on: 2004/1/20 5:30
Whats the deal with fuel pump setups/regulators if i was to run with the twins?
Electric I'd imagine.....am I right.......more$$$
As I mentioned I'm really wanting more acceleration and off the mark power not so much top end power and speed - I've always believed in building engines for maximum torque and the rest should fall into place.
#6 Re: Single Side Draught
1200rallycar Posted on: 2004/1/20 5:33
some use the mech pump it think, i had an electric pump with a regulator, pump was $40 regulator was $55, but i have found a place to get pumps for $10, you can get em at wreckers off some geminis and pulsars and stuff (should be pretty cheap)
#7 Re: Single Side Draught
Buff Posted on: 2004/1/20 5:43
I'm sure B120 will be here in a sec to tell me to stop being soft and get the twins
But When you sit down and plan a rebuild properly she soon starts adding up
Plus a decent set of twins and manifold ready to go seem so hard to find these days especially when dealing interstate
B120???????????
#8 Re: Single Side Draught
1200rallycar Posted on: 2004/1/20 5:50
thats alright ill tell him to stop being soft and get injection, as i always do, o and to get a turbo not a super, and blow through not suck through, and to put a thermo fan on
hang on a minute, i dont think he listens to me much
oh, and he's piked on the SR20VE plans he had
hehe, that should get him going
#9 Re: Single Side Draught
1200rallycar Posted on: 2004/1/20 5:55
add me to your msn:
rallycar_1200@hotmail.com
#10 Re: Single Side Draught
Buff Posted on: 2004/1/20 6:30
Got cha 1200rallycar
