Re: Which thrust bearing carrier? (60a 5speed into 120y)
From Wellington
It still seam very odd to me, I cant work out why it would work as you have decribed your set up has not changed (apart from a new clutch) from the 4 speed set up that was working fine...........so the new parts are the new clutch, do think it possible that this is doggie.....otherwise its adjustment in the cable. Grab the cable at the fire wall and pull it hard, you should be able to pull some out from the fire wall, what does this do to the pedle....it the pedals on the floor then its to slack and needs to be adjusted tighter. I think fitting the short carrier is going make it worse and therefor an even alacker pedal...
Posted on: 2011/1/20 8:13
Subject Poster Date
     Which thrust bearing carrier? (60a 5speed into 120y) SunnyDaze 2010/11/7 1:00
       Re: Which thrust bearing carrier? b310gx 2010/11/7 4:41
         Re: Which thrust bearing carrier? Weekend1000 2010/11/8 12:53
           Re: Which thrust bearing carrier? (60a 5speed into 120y) SunnyDaze 2011/1/18 14:11
             Re: Which thrust bearing carrier? (60a 5speed into 120y) Datsss 2011/1/18 21:26
       Re: Which thrust bearing carrier? SunnyDaze 2010/11/9 10:27
         Re: Which thrust bearing carrier? SunnyDaze 2011/1/9 8:38
       Re: Which thrust bearing carrier? Anonymous 2010/11/9 10:30
       Re: Which thrust bearing carrier? (60a 5speed into 120y) SunnyDaze 2011/1/9 9:39
         Re: Which thrust bearing carrier? (60a 5speed into 120y) ddgonzal 2011/1/9 21:19
           Re: Which thrust bearing carrier? (60a 5speed into 120y) Datsss 2011/1/9 22:13
             Re: Which thrust bearing carrier? (60a 5speed into 120y) SunnyDaze 2011/1/9 22:25
       Re: Which thrust bearing carrier? (60a 5speed into 120y) SunnyDaze 2011/1/19 10:44
         Re: Which thrust bearing carrier? (60a 5speed into 120y) clyons8 2011/1/19 10:50
       Re: Which thrust bearing carrier? (60a 5speed into 120y) SunnyDaze 2011/1/19 11:01
       Re: Which thrust bearing carrier? (60a 5speed into 120y) clyons8 2011/1/19 11:26
       Re: Which thrust bearing carrier? (60a 5speed into 120y) SunnyDaze 2011/1/19 11:37
       Re: Which thrust bearing carrier? (60a 5speed into 120y) Anonymous 2011/1/19 12:14
       Re: Which thrust bearing carrier? (60a 5speed into 120y) SunnyDaze 2011/1/19 12:19
         Re: Which thrust bearing carrier? (60a 5speed into 120y) Datsss 2011/1/19 20:25
         Re: Which thrust bearing carrier? (60a 5speed into 120y) SunnyDaze 2011/1/19 21:25
           Re: Which thrust bearing carrier? (60a 5speed into 120y) Datsss 2011/1/19 21:43
             Re: Which thrust bearing carrier? (60a 5speed into 120y) clyons8 2011/1/19 22:09
       Re: Which thrust bearing carrier? (60a 5speed into 120y) SunnyDaze 2011/1/20 4:56
         Re: Which thrust bearing carrier? (60a 5speed into 120y) clyons8 2011/1/20 5:01
       Re: Which thrust bearing carrier? (60a 5speed into 120y) SunnyDaze 2011/1/20 7:36
         Re: Which thrust bearing carrier? (60a 5speed into 120y) clyons8 2011/1/20 7:53
           Re: Which thrust bearing carrier? (60a 5speed into 120y) clyons8 2011/1/20 7:57
           Re: Which thrust bearing carrier? (60a 5speed into 120y) SunnyDaze 2011/1/20 7:58
       Re: Which thrust bearing carrier? (60a 5speed into 120y) Datsss 2011/1/20 8:13
         Re: Which thrust bearing carrier? (60a 5speed into 120y) Datsss 2011/1/20 8:18
       Re: Which thrust bearing carrier? (60a 5speed into 120y) SunnyDaze 2011/1/20 11:02
       Re: Which thrust bearing carrier? (60a 5speed into 120y) SunnyDaze 2011/1/21 9:18
       Re: Which thrust bearing carrier? (60a 5speed into 120y) b310gx 2011/1/21 9:50
       Re: Which thrust bearing carrier? (60a 5speed into 120y) SunnyDaze 2011/1/21 9:52
       Re: Which thrust bearing carrier? (60a 5speed into 120y) b310gx 2011/1/21 10:20
       Re: Which thrust bearing carrier? (60a 5speed into 120y) ddgonzal 2011/1/23 2:07
       Re: Which thrust bearing carrier? (60a 5speed into 120y) SunnyDaze 2011/1/26 9:16
