« 1 ... 27 28 29 (30) 31 32 33 ... 42 »
Re: Project Drift coupe (AKA 1200 coupe )
From Freo
why is that Dagski? heavier, costs more, the CA is in and running...
Posted on: 2011/1/27 15:15
A15 PSI Project Motor
'72 CB750k,
Dazza rebuilt to standard spec? so he used graphite head gasket? thats the reason most fuk up.....
Posted on: 2011/1/28 1:41
From mandurah
yea and black tops have too much wiring involved ,its easyer to run an after market computer cos the standard one is intergrated into the cars harness !
yea im gettign a steel haed gasket and arp studs soon
need to pull the plugs out and check before i say anything
might just be timing and the idle enrichment setting the timming up wrong
Posted on: 2011/1/28 4:18
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From mandurah
work day this sunday ,should be good ,nigel you in ,oh wait your working arent you ??
should get abit done ! carps has his welder too so hopefully the welding work will be done by the end of the day !
Posted on: 2011/1/28 4:24
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
could be waiting waiting....
Posted on: 2011/1/28 5:01
From perth airport
man i love reading about all the pronlems with ca18's if bring be back to when i had 6 of em all crap and kept thinking the datto guys must be right .....
Posted on: 2011/1/28 5:52
perth airport parking
Datsun 1200 ute A14
lol.... your just jealous u dont get to change head gaskets every second weekend
Posted on: 2011/1/28 8:30
From perth airport
and the rest
my sr20 drift car has now last'd a year of jordy driving eg 60 brand new tyres and a heap of second hand ones with one problem a crack'd rad
every sr20 i have had has been this good or better
every ca i have had has been a head fuk
Posted on: 2011/1/28 9:18
Datsun 1200 ute A14
From mandurah
i know jordy but ive got it so when it actualy blows up ill; get an sr ,but for the mean time im going to keep it
and as for electrical problems ,i can adapt nearly any tps to it with the right throttle body (ford falcon ,heap easy to get) and the afm i can get rid of and run a map sensor
and if i have problems with the computer i could always buy a stinger cheap and fit it myself
but for the mean time im going to suss it out and if its got a blown head gasket ill put my spare one on hahah but as i said head studs and steel gasket are on the way !! (when i can be #OOPS#ed getting them)
oh and i cut my dash piece out today ,kinda hard to get the shape right to start but im going to use a flap wheel to fix the shape abit then get my gauges !
Posted on: 2011/1/28 9:33
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
From mandurah
ok i think ive sorted the popping out ,i did what bailz said an pulled the temp sensor off with water in it ,made some difference
so i then adjusted the timing and it fixed it completely ,now it starts good adn idles with water in the system and doesnt pop !!
Posted on: 2011/1/28 13:40
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
