120Y - how does the base of the plastic front grille attach?
From Brisbane
The top of the grille attaches no problems, there are half a dozen trim screws that go into nylon holders.
The bottom of the grille is loose, and there seem to be mounting holes in it, but there's nothing to mount it to. Has anyone got a picture of whatever-it-is under there that it's supposed to mount to? I obviously need to make one up, or get one from the wreckers.
Posted on: 2011/1/24 22:06
Re: 120Y - how does the base of the plastic front grille attach?
On my 120y grilles there are little pins that just sit in holes on the car. I can have a better look tonight.
Posted on: 2011/1/24 22:34
From Townsville, Qld
3 or 4 L brackets with rubber grommets I believe, I'll go take a picture.
Posted on: 2011/1/27 4:41
From Brisbane
Hey guys, any luck? :)
Posted on: 2011/1/31 3:56
From south coast nsw
mine has lugs on the grill that slip into the holes on the brakets coming off the middle radiator support.either u have no braket there or no lugs on the grill maybe,mine 77 coupe but...
Posted on: 2011/1/31 4:38
From RAdelaide
As said before the three lower brackets ( flat steel with hole and plastic grommets in them ) only stablise lower section. All screw points are at top as you've found. Just check the grill around the headlight isn't catching on lights or guard edges
From where your up to- lean grill forward say 20degrees and pull up
Posted on: 2011/1/31 8:23
"My mind is a raging torrent, flooded with rivulets of thought, cascading into a waterfall of creative alternatives." - Hedley Lamarr, Blazing Saddles
Sorry Shifty I've been doing stuff for this deathstorm the last few days.
*sigh, half of my crap is outside
Posted on: 2011/1/31 12:47
