finally found thread again sorry RC I took a wrong turn somewhere
The open chamber and close chamebr head is found on pulsars but the low comp one is when the chassis plate doesnt display the "S" option. I found one of these heads and went crazy when I saw that the ports where as big as the gx head I had at the time and a worked close chamber a15 head.
Then spoke to Gerald at mammi motors and he said that this head would make a perfect high boost turbo head for the "a" cause of its hemi like chamber dome shape.
After all in theory it would provide an even burn toward the piston in a turbo setup as opposed the closed chamber kidney shape.
removing piston material on cast ones for turbo is not considered safe for strength.
Unless tried though its all theory whether its the wrong path or not.
So the question is which setup would work best at 7.8 to 1... a dished piston or open head resembling a dome a-la hemi style?
The other thing if it is by piston that the compression is going to be lowered then angle shaving the head to have the valves parallel to the pistons would be ideal for extra squish, as long as the pushrod dont become a problem.
