a14/15 conrods question
From Vanderbijlpark, South Africa
hey all, just want to know if the a14 conrods will work on a a15 crank and block, the a15 sub i bought seems to have the conrods shortened as the pistons are about 2mm from the face of the block when engine is tdc. i'm building na high compression so this might be a draw back. i'm planning to put 78.5mm mazda e5 high comp pistons in, i know the mazda pistons needs the gudging pin hole modified and also some mm's taken off the top of the pistons, which i might n not need to do since the conrods are shorter. any suggestions will be appreciated
Posted on: 2011/2/10 7:01
93' Nissan 1400 a15 60a (daily)
82' Datsun 1400 ute (sold)
73' Datsun 1200gx Coupe (sold)
Re: a14/15 conrods question
From sydney.nsw
check the stroke , it may be a a14 crank in a 15 block
Posted on: 2011/2/10 7:09
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
They are the same
12100-17200 A14/A15 CONNECTING ROD 133mm/5.24" center-to-center
See Connecting Rods
i checked the stroke, its 82mm which is a a15 as far as i know. thanks for the info
Posted on: 2011/2/10 7:37
A14 And A15 rods have a different pin to crown height pretty sure it's 2mm or so. Maybe that's what it is? (A14 rod and pistons in A15 block).
Posted on: 2011/2/10 8:54
From Perth
Rods same
Pistons different
Posted on: 2011/2/10 10:00
Quite a regular
From Olympia, WA, USA
"Pin Height: The A15 piston has a 30mm pin to crown height, while the A14 has a 32.5mm height "
Sourced from Tech Wiki
http://datsun1200.com/modules/mediawiki/index.php?title=A15_Engine
Posted on: 2011/2/10 15:49
