Master Pump Problem
From Sri Lanka
Hi Guys
I have replaced the Master pump and all brake washers, after that
i have a problem now master pump doesn't deliver oil into break and cluth lines, what would be the case any suggestions ?
The Piston which is having 2 Rubber Washers on top has to be inserted first into the master pump or the other one ?
I got stuck on this , need you guys help please,immediate response is appreciated
thanks
regards
sumith
Posted on: 2011/2/16 16:05
Subject Poster Date
     Master Pump Problem Sumith 2011/2/16 16:05
       Re: Master Pump Problem ddgonzal 2011/2/17 4:17
         Re: Master Pump Problem Sumith 2011/2/18 6:07
           Re: Master Pump Problem ddgonzal 2011/2/18 6:22
             Re: Master Pump Problem Sumith 2011/2/18 6:37
               Re: Master Pump Problem clyons8 2011/2/18 6:45
                 Re: Master Pump Problem ddgonzal 2011/2/18 6:49
                   Re: Master Pump Problem Sumith 2011/2/18 7:04
                     Re: Master Pump Problem ddgonzal 2011/2/18 7:11
       Re: Master Pump Problem Anonymous 2011/2/17 8:44
       Re: Master Pump Problem dattoman_1000 2011/2/18 10:59
         Re: Master Pump Problem Sumith 2011/2/18 11:08
         Re: Master Pump Problem dattoman_1000 2011/2/20 3:40
