ute diff center
From penrith,sydney,aus
im after a 1200 ute diff center
must be unlocked
im located in penrith can pickup
cheers
Posted on: 2011/2/14 22:03
2 door 1200 sedan project l20b stroker
Re: ute diff center
From Armidale N.S.W
Got a H165 series 2 bluebird auto diff centre if thats any good to you. Obviously it will fit but ratio may be no good for you.
Posted on: 2011/2/15 0:27
73 1200 wagon SOLD
Re: ute diff center
hey mate thanks anyways but probably to far away
cheers
Posted on: 2011/2/15 3:02
Re: ute diff center
From Armidale N.S.W
Nah not to far to post mate there under 20kg. $50 including postage if ya want it.
Posted on: 2011/2/15 3:17
73 1200 wagon SOLD
Re: ute diff center
what ratio are they, they are 3.9 arent they, also are they the same length as a ute center???
Posted on: 2011/2/15 3:41
Re: ute diff center
From Townsville, Qld
You need to swap the flange on the diff as the bluey one is around 10mm longer and will cause binding at certain angles. Have to be careful doing that as well cause of the crush bearing on the pinion shaft, that part of the diff annoys me
Posted on: 2011/2/15 6:53
Re: ute diff center
What sort of ratio are you after?
Posted on: 2011/2/15 7:00
Re: ute diff center
From Sydney
I was not aware that H165b centres are different in length. Are you sure?. i have used H165b's in ute housings before and have not noticed any physical dimensional difference.
And at a guess I think Shaun is after a Ute centre i.e 4.1:1 ???
cheers
benny
Posted on: 2011/2/15 7:37
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Re: ute diff center
no not the carrier itself Benny, just the yoke\flange whatever you want to call it. It's easier to get the bolts off the bluebird tail shaft cos of it.
edit: I've plopped a bluey 165 into to a ute housing here, no dramas at all. Same would go for a Stanza 165, I suspect it's got the same flange plate as teh bluebirds. I was thinking of shortening one of my H150 shafts to match the longer flange plate since I have more of them but I can't justify that sort of work at teh moment unless I'm sitting on more money.
Posted on: 2011/2/15 7:44
Re: ute diff center
From melbourne
I would be interested in that diff . 3.9's or 3.7's 0412853794
Posted on: 2011/2/18 6:32
