Re: Master Pump Problem
From Sri Lanka
Hi DD
Yes i only used brake fluid nothing else, when moving outer piston downwards do you feel the inner piston is also moving ? i feel only outer piston moves down and come up only
is that the problem there ?
but individually i checked them both are moving down and up
thanks
regards
sumith
Posted on: 2011/2/18 7:04
Subject Poster Date
     Master Pump Problem Sumith 2011/2/16 16:05
       Re: Master Pump Problem ddgonzal 2011/2/17 4:17
         Re: Master Pump Problem Sumith 2011/2/18 6:07
           Re: Master Pump Problem ddgonzal 2011/2/18 6:22
             Re: Master Pump Problem Sumith 2011/2/18 6:37
               Re: Master Pump Problem clyons8 2011/2/18 6:45
                 Re: Master Pump Problem ddgonzal 2011/2/18 6:49
                   Re: Master Pump Problem Sumith 2011/2/18 7:04
                     Re: Master Pump Problem ddgonzal 2011/2/18 7:11
       Re: Master Pump Problem Anonymous 2011/2/17 8:44
       Re: Master Pump Problem dattoman_1000 2011/2/18 10:59
         Re: Master Pump Problem Sumith 2011/2/18 11:08
         Re: Master Pump Problem dattoman_1000 2011/2/20 3:40
