« 1 ... 14 15 16 (17) 18 19 20 ... 22 »
Re: datski's 1200 sedan V1.2
From Perth WA AUS
Do I detect a hint of whoring Mik? Naughty boy, thats against your rules!
Posted on: 2011/2/18 11:54
Datsun 1200 2Dr sedan.
From mandurah
pfft mik would never do that nigel hehe
so is it going to be a steel over foam pad and your then going to cover it in fabric ??
should look good ,but im not sure how crashable it ill be ,might hurt head you hit it oh wait it will hurt in a crash anyways !
Posted on: 2011/2/18 13:06
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Albany, Perth Australia
It will have high density foam over the top and new vinyl over the whole lot....
Posted on: 2011/2/18 13:44
1200 Smerf Mobile
well me jesse and nige got some work done to my sedan....cut more rust out in the floor plan on the drivers side, cut the gutters off the drivers side and repaired the roof on both sides. Jesse got the front end put back together and after mucking around got the gearbox in, and also got the diff in. Nige worked on the drivers side rear and got it pretty much ready for paint. so here are some pics
Posted on: 2011/2/27 11:19
1200 Smerf Mobile
From mandurah
nice work on the floor brett ,i didnt realize you got the patch completely welded !
if only the bush had of gone in i could of put all the wheels on and have it rolling again :(
Posted on: 2011/2/27 12:55
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
Shouldn't take me long to get them in just needs a bit of persuasion....and need to get the right size bolts for the gearbox to bolt it up nicely and put the sway bar back on
Posted on: 2011/2/27 14:00
1200 Smerf Mobile
From Perth WA AUS
I got a new welder!
Posted on: 2011/2/28 6:59
wicked stuff nigel...does that mean you get more wire as well
Posted on: 2011/2/28 9:23
1200 Smerf Mobile
From Perth WA AUS
Kind of ( I forgot to take the old wire out first), but it works very well on the high setting now :)
Posted on: 2011/2/28 10:44
From Perth WA AUS
I think my welder is better than yours Bretski, example:
jpg  weldcorp.JPG (67.74 KB)
9665_4d6cb2043a718.jpg 778X581 px
jpg  Your welder.JPG (78.34 KB)
9665_4d6cb211989a6.jpg 778X581 px
Posted on: 2011/3/1 8:45
