From St. Louis, MO USA
I am a racer here in the US. Sometimes I buy pistons for a project that does not happen. Here are some NEW pistons sets for sale at a discount. [Original selling price was $550 USD, now it is $700 USD! I might not be selling any new piston orders.] ALL NEW PISTONS come with new pins, new rings and new pin clips.
$375 USD - 74mm Wiseco forged pistons with wedge dome for a GX head. These have the pin height (from center of pin to top of the flat part of the pistons) as stock for an A12, A13, or A14 (although they are smaller bore than an A14). The pin or compression height is 1.279 inches, or 32.5mm.
$375 USD - 76mm JE forged pistons with wedge dome. These have a pin height as stock for an A15, so they are approximately 0.199 inches or 5mm shorter than an A12, A13, A14 piston. The compression height is 1.080 inches, or 27.4mm. If you use them for an A15, fine. IF you use them in your A12, A13 or A14, they will sit 5mm below the deck, but you will have lower compression that a piston sitting at the deck height. Here in the US we use these pistons with an A12, A13, or A14 but we can use longer con rods and can machine off the top of the block.
Shipping for a set of pistons to Australia, New Zealand, South Africa is $60 USD.
Email is best PeterZekert (at) Juno (dot) com
Thanks, Peter
Posted on: 2011/2/22 14:53
Edited by pjz on 2011/2/22 15:29:54 Edited by pjz on 2011/2/22 16:05:04 Edited by pjz on 2011/2/24 3:04:10
