Browsing this Thread:
1 Anonymous Users
Re: Estyres 1200 ute build thread V1.0 |
From mandurah
ok update ,im still broke ,but i have been pricing up stuff for the a15 ,im keen to get the ball rolling with it when my ute is sorted
so far ive got on my list of WANTS and i think i need all of them ,at the moment i want to most power i can possibly get with out boost (yethehe)
so i figure if i build a realy good bottom end and have a head that will give me a good amount of comp ,then if i want to go turbo later i can just put a non shaved head ona dn not have to worry about the bottom end needing any work !
so here gos
tomei light weight push rods =$115 rocker shaft collars =$80 LARGE EX valves 32.0mm =$199 LARGE IN valves 38.0mm =$199 Racing adjustable timing chain tensioner =$126 metal head gasket 0.8mm =$226 heavy duty timing chain =$138 adjustable timing gear =$235 heavy duty rocker shaft =$117
then there is still pistons and bearings and rings ,oh and machine work !
i was told forged ross pistons are $1100 with rings ,but ill have to check with ernie as for bore size ,how big can i go before it will get hot ? i want the most cubes i can get SAFELY
any ideas? and what of the above do i actualy need? its all nice stuff but no point buying it if its not needed
and who streetable would an a15 be with heaps of comp ,twins and a cam
the cam doesnt worry me ,i can put up with it jerking around ,but will it be reliable in the long run ?
thanks
Posted on: 2011/2/20 9:35
77 1200 ute 77mm bore a15 ,12:1 comp ported and reconed h89 head fairly aggro cam ,billet rocker spacers twin 40mm solex carbs on bpro manifold MSD 6al2 with 2 step limiter 4speed 60a box hd clutch 2 inch exhaust locked 4:11 ute diff ...
Dude learn from others mistakes.... If u want reliable go for a fuel injection setup already! Haha carbies are old skewl!  a15 with fuel injection is reliable. Will start more often than a a15 with twins ;)
Posted on: 2011/2/20 11:06
From Perth WA AUS
Yeah, mine is very grumpy until it warms up (about 20 minutes later).
Posted on: 2011/2/20 11:59
Datsun 1200 2Dr sedan.
Levey your motor is off tap! That thing was psycho in that wags. Jesse if your going for reliability a12-15 that's had a freshen up would be the best for reliability
Posted on: 2011/2/20 13:26
From Mandurah, Western Australia
Why not stick with what you got for now, tidy up the panel work and interior etc. Get the coupe up and running and see how that goes, then focus on the ute. You might realise how good the CA setup is and swap it into the ute. If you want to go A series why not look at adapting EFI from a Hyundai Excell or something else with a simple fuel injection setup.
Posted on: 2011/2/20 14:22
From mandurah
yea i was thinking of trying that jarrad ,but i want a screaming a15 with twins ,but for the street twins arent going to work for my ,maybe itbs ??
Posted on: 2011/2/21 13:42
From Freo
how can people say twins are no good??? Nige has a set on his 15, Ben has a set on his 15, as have countless others, Alfa had twins standard, Fiat had them, Toyota had them,
once set up.. trouble free motoring..
EFI costs the same if not more to buy, and still needs tuning....
Posted on: 2011/2/22 0:09
'68 Thou Wagon,(home now) up and running '69 2 door project, the yellow thing, A12A Project motor, for the yellow thing. A15 PSI Project Motor '72 CB750k,
From mandurah
yea its just what everyone tells me is twins are high maintainance and wont be any good for a daily drive but i think they might just be jealous ! haha they look and sound mighty fine !
i just want them sorted ,then i can actauly go to cruizes and stuff and not have to worry about breaking down due to the carbs playing up ,and i want them to run smooth ! i hate studdering ,and popping !!!!
Posted on: 2011/2/22 9:51
From mandurah
ok the ute is now tuned !!!
i payed tim today and i was expecting a bill of around $500-$1000 but i was plesently suprised when he charged me $200 including brand new jets ,reprofiled idle screws and a sick sticker !!!
so im realy realy happy ,the bill is paid and i have to pick it up tomorrow ,so i ge to give it a right thrashing through the industrial area hahahaha
it doesnt pop anymore and it starts like a dream ! ,only thing is it doesnt do much till about 3000rpm and you feel the cam kick it up the ass ,goes good now and ive got some stocky inch rims im going to paint black and put my pimpin 165/60/13s on haha then i don thave to worry bout hurting my jellies or my good tyres !
im almost ready to take it to any up coming cruises ,i need to change the rad cap or put a overflow bottle on as its a recovery cap and it will just pump itself dry unless it has a tank on the side
ok next thing i NEED to gtet done is panel work ! i need new sills put on and then i need tem painted ! ,whos keen to tackle it with me ??? ill cut them off soon and get a set made ,then ill need someone with the skills to weld them on and not warp the quarter or the inner door seal area
anyone think they got the skills ? any time haha ill pay too !
Posted on: 2011/3/2 12:47
Buy the sills off eBay. So much easier and will be a better finish if u do it right. Only way I could do the sills is if u drop it at mine for a week.... But u won't leArn how to do it.. ;) and I dun have the time hahah :( Maybe once I finIsh my final Exam I could have some time
Posted on: 2011/3/2 13:06
